How's everyone doing? Great I hope. Have some time to post a watch that I've been working on. I've learned from experience that the cheaper the watch, the more difficult it is to work on. Here is something from the 70's that represents well that kooky period. The watch measure 40mm x 38mm. The power comes from a one-jewel Bettlach 8800 with a jump hour mechanism on the dial side. An example of what makes this watch a nightmare to work on? For starters, you have to press down hard--and I mean with your body weight--on the stem release button to get it to release. The movement has what I think is a dust cover(why?), which when placed incorrectly causes the balance wheel to rub and stop--but only intermittently so that you go crazy trying to figure out what's happening...
Its not me, its the WATCH!!
J
DSCN5244_tn.thumb.jpg.38b81fdd57ce0a77abd3d4710192ce35.jpgDSCN5081_tn.thumb.jpg.170983dcb97900e64134566571c24296.jpgDSCN5083_tn.thumb.jpg.8c5cc1220ad54caa7b351547341fb0bd.jpgDSCN5084_tn.thumb.jpg.404e4bc22ce77c14e99a451e1d320786.jpgDSCN5243_tn.thumb.jpg.0bf8d7e3aec978e70c07cc68144c112d.jpg
Edited by noirrac1j
Ooh, pretty on the outside but ugly on the inside.  At least you have yourself there a Swiss pin lever movement. ^_^
I think mechanical watches from back in the day are what lead to the saying "you get what you pay for".
Expand
Yeah, it's a whole lot of chromed-shininess and not much substance! It is however, in excellent shape for being 40+ years, so it has that going for it.
J
I dread working on these movements. They have no jewels for the pivots so on the vintage movements the pivot holes are nearly always worn especially the pallet bridge. This makes it really difficult to get the movement to run smoothly.
Expand
You've summed it up nicely. These things can be a tremendous hassle, but when they run, they do the job.
Expand
Yep they do the job and surprisingly for many years. Just don't beat yourself up trying to get nice smooth readings on your timographer.
If the stem is that hard to move then put a little grease on the parts that touch each other, add a little oil to the stem, make sure you don’t have the wrong screws holding things together that might protrude and foul up the setting hands parts.  These old EB movements sure are bog standard, but a hell of a lot better than a ruddy Timex.
Expand
Yes I put some Moebius KT gease and also lubricated the stem. Its not as bad as it used to be but still very stiff to release.
J
I remember I had to kick one off the bench as its loud tick was too distracting,
Problem was they did not use jewels to save money, so they used plain holes. This in turn increased friction which required a more powerful spring. The powerful spring overcame the friction problem but led to faster wear if not serviced regularly.
Anilv
Anilv
Expand
Very loud ticking! Yes these are not meant to last that long, and yet here they are 50 years later!
JC
True Noirrac1J,
Also we have to acknowledge that Oris, which was one of the main proponents of the pin-lever (some even chronometer grade!), was one of the main forces behind the resurgence of the mechanical watch in the late 80s.
Also without Sicura (another pin-lever brand), we may not have Breitling with us now.
Anilv
  On 6/21/2017 at 4:00 AM, anilv said:
True Noirrac1J,
Anilv
Expand
Right on both points!
J
  • 3 years later...
  • Similar Content
    • Hi all. This is my first post for repair advice so I’ll do my best to explain what info I’m looking for.  I have a minute repeater in a rolled gold hunter case but the stem and crown are missing. looking at the movement it is Swiss made and operates well. I’d like to make or purchase the stem but I’ve found a crown that fits. The case is a Thomas Russell & Son (Uk) but also marked Elgin so a US.case. the neck (if this is the correct terminology) that the stem goes through and into the movement doesn’t have any threads either internally or externally. My first question is, would this have a sleeve that goes in to the neck that the stem would go in to? I’ve looked tirelessly to find info on this particular movement for information on the stem configuration but everything I’ve found differs slightly from this. Some have stems screw in to the neck and some just sit in there. Second question, how would the stem be secured in place on this movement? I’ve found a another stem and crown and it winds well and moves the hands but it’s the wrong stem but the crown will be fine. Oh looks like the hour hand is wrong and it’s missing the seconds hand too. Anyway that’s it for now, there’s only so much I can digest. I look forward to your advice and hope for documentation on the correct stem/sleeve/crown  to get this beautiful watch running again. Many thanks  mark
    • Your diagnosis of a missing screw is probably correct - the tip of it should be visible in your photo but is not. However, installing the screw still may not fix the problem if the Date Click Spring (2576) is worn out. Those very thin metal parts can wear down where they insert into the plate, causing them not to stay affixed as well as they should. But replacing the screw first would be good to test. I do not think it is the same screw as in the rotor. In the M31 diagrams, the rotor screws appear shorter than the "short" pillar screw. But the screw threads should be the same for all the pillar screws, for all Timex movements. If you obtained a junk Timex movement from ebay or elsewhere and removed one of the regular pillar screws (5100), I expect it would fit that hole. I think you could use any Timex >M24 mechanical movement to get a fitting screw. If it was too long protruding and interfered with something on the back of the movement (like the rotor), you could file the tip of the screw down until it no longer got in the way. I suggest this because again, I do not expect a watchmaker to be willing to help you source this part.
    • Hello and welcome from Leeds.
    • Hi All I’m Mark a new member from the UK. I have a long standing interest in clocks and very recently pocket watches. I ended up here after purchasing a minute repeater in a rolled gold hunter case and looking forward to seeing repair advice on this. I hope to have lots of fun with my new found interest and I look forward to hearing from you soon. Thanks Mark 👍
    • Any way to fix dials to movements you can think of and more has been tried Glen. The dial is maybe not original, to the watch. The problem with dial dots, if the adhesive gets for whatever reason, they ease up on holding the dial in place. Attaching feet is a nice permanent solution, if you want to go to the trouble of it. Its a tricky process with risks however you do it. I'm not sure I've seen dials without feet before, but probably.  Often they are there and only push on to the movement with dial feet screws.
