Girocap spring
I have a Universal Geneve 215 movement in a Polerouter watch. The escape wheel has shock protected cap jewels known as Girocap (occasionally misspelt Gyrocap), made by Porte Echappement SA.
One of the shock springs is broken in half and whilst I have the watch running and the jewel seems to stay in place I can see this being a risk. I have tried in vain to work out where to buy these but don't see them listed anywhere. I have seen various movements and parts on ebay with them, but rarely see UG 215 parts and if so they are usually the wrong side of the pond and expensive.
Does anyone know if these were all one size or if they are as varied as incablocs? If all one size I could buy a cheap scrap movement.
Thanks
S
Seen that on other UG movements also. Can't find a good picture right now but i now how it looks.
Seen this btwhttp://www.polerouter.de/frameset-movements.htm
Yes, I've spent quite a bit of time looking at that, and som while back I asked the site owner if he could send me a better copy of the oiling chart, but never got a reply.
The Girocap was used on the Omega 540 balance and there's a description in here
http://watchguy.co.uk/wp-content/uploads/2012/12/Omega-540.pdf
There's a good picture her and also a useful reference for identifying shock spring types
https://watch-wiki.org/index.php?title=Kategorie:Picture_gallery_archive_shock_absorber
I also found this on eBay, so definitely not a one off
Seen them in other movements. Did a little search and found them in Certina and Tissot movement. Also in some AS and an MST 469 . Maybe they could be found on cousinsuk under the movement? Omega had a complete one but at £60 it wasn't cheap?
  • 6 months later...
Well Rogart, I came back to this after a few other distractions and your inspiration led me to track down a Roamer mst 466 which was only £6 incuding postage. I couldn’t find out if there were multiple sizes of Girocap, but I figured I had little to lose here so went ahead and bought it.
Sadly, whilst I have answered a question, it’s not the answer I wanted. So I now know that Girocaps came in more than one size and the springs aren’t interchangeable.
Roamer 466 will doubtless be back on the bay soon! Will have to look for a movement of a similar size to the Universal 215 with a Girocap and then find a cheap one of those to buy. Have not found Girocap parts anywhere else :wacko:
  • 9 months later...
    • Oh well, if Master @nickelsilver says it's the way to go, then it is the way to go! I stand corrected! 🫡 Are there any other places where you're supposed to remove the epilame from the contact point of rubbing? I don't think so! Thanks for the effort @Neverenoughwatches, much appreciated! 🙂👍
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
