Selecting a Tension Ring crystal
I need to get a new crystal for a watch I'm working on. It has a tension ring type glass. I've never bought this type before and have a couple of questions that someone may be able to help with.
How do i measure the glass. The case opening is 32.45mm what size would be appropriate.
There seems to be a couple of types on the Cousins site. Standard and Recessed. What does recessed actually mean? the glass the came out does have a recess where the ring sits, is that what it means?
Thanks for any help.
I'm curious as to what kind of watch it is .  Seiko has case to crystal lists .
Can you measure the old crystal diameter . A tension ring crystal will have a white or gold ring you specify when you order and be very slighter larger then the case opening .
I order from Tip Top Crystals quite a bit , and you can email Steve and ask questions .
If your watch case have  a recess where the crystal is you should have a recessed crystal. But i think you should have a ACT crystal with chrome or gold tension ring. This is the most common crystal.  32,45 i would go for a 32,6 or maybe a 32,5 but a 32,6 would be just about right i think?
The glass that came out is 32.50, but I can push it in by hand, so I think 32.60 would be the one. It's only an Avia, so I assume the standard glass will be right, as stated by Roger.
Since you need to order a crystal w/tension ring that is larger then the case measurement then you need to compress the edge of the crystal to get it to fit . Once the edges are in then you can seat it with a press . I usually use a press with my divers that have a crystal gasket to fit to .
Maybe others can give their methods and opinions .
As a matter of information. I bought a 32.5 and it was a perfect fit. I had to use the press to get it fully in. So it seems you don't want to go too big. Also, the crystal lift tool was no use at all, as you can't compress the tension ring. I guess that's the idea really.
Anyway, that was my experience, YMMV.
Way to go ..  You got it in without damage and it stays in . Can't ask for more then that .
  • 5 months later...
Rather than starting a new thread, can I ask about this crystal. There are so many to choose from, I'm not sure where to start. It seems the one I have the chrome ring actually holds the dial in place ie, if I put the dial in the case with out the crystal on, there is nothing stopping it falling out the front of the case.
The watch is a Tissot seastar
    • Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
    • Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
