Todays Rubbish
oldhippy
To days rubbish from ebay. Its modern, note how the seller describes it as French style. The movement is nothing more than a modern cheap Westminster chime; the type of movement you would expect in a mantle Westminster chime clock of today, the only deference is it has been adapted for a longcase.  Don’t waste your money.
Gorgeous French Boulle style long case clock
http://www.ebay.co.uk/itm/French-Boulle-Work-and-Lacquer-Long-Case-Clock/262908255970?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D2ea0349d44bc4fe1a93d5e26cb29bcd1%26pid%3D100033%26rk%3D4%26rkt%3D8%26sd%3D182500752823
But it was purchased from a dealer on Rue de Rossiers at the Paris antiques markets, so it must be old and genuine. :biggrin:
Maybe the gold coloured bits on the front aren't just gold paint, but actually solid gold.....................
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task and full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
