Hello from Salvatore
By rob1crazydude · Posted
my wife picked up this Wakmann at a yard sale for a DOLLAR! then brought it to me and asked if i wanted it!!! i ordered from Gleeve , pushers, crystal,gaskets and cleaned it up spme,, waer it everyday now i need a return to zero part cant remember the nuber right now thats why its not zero'd -
So I managed to straighten the pivot by holding the pinion in a pin vice and slowly rolling the pivot on hard metal surface while pushing on the side opposite the bend with tweezers. Just like in the video Mark posted earlier. I didn’t heat it but, if I need to do it again I will as it does make sense to do that I think. My backup was to order a new wheel but repovoting sounds interesting. It looks a bit out of my league at the moment though as I don’t have a lathe or the skill to use it! I’ll try leaving the canon pinion on longer for some added protection; it’s usually the first thing I take off. I would want it removed before taking off the train bridge though I guess. In this case though I think the solution is that I need to be more careful when dealing with the extended fourth wheel pivot!
Pretty decent close-up photos can be acheived with a clip-on macro lens attached to a handphone. 15x Micro Lens Pink Phone Camera Lens Clip Light for Manicure Beauty Eyelash Nails Macro Photography Lighting Tool Adjustable https://a.aliexpress.com/_mP5iKcR -
Thank you and thank you! I've been looking for this for weeks. I struggle a bit sometimes sourcing parts. Thanks Again.
