I joined last summer but before I could post much I was in a car accident and injured my right hand.  Once I recovered enough to be able to both type and work on my watches I had a back log of watches to repair. That along with my day job to keep me busy for a few months.  Now that I am caught up and healed up I can start posting.
I live In Texas near Dallas and repair watches as my second job.  I am a Electronics Engineer, Systems Engineer and Machinist.  Currently I am learning mechanical watch repair or I should say learning more about it.
I do repair quartz watch movements and electronic watches.  I have a few old LCD and LED watches. I also have a collection of Timex and Bulova watches.
Hey, Sleeper!
Welcome back.  Sorry to hear about your accident, but glad you're recovering.  I'm in Texas, too.  I am south of Houston in Pearland.  I have some vintage Bulova parts, if you ever get in a bind and need something.  At the moment I'm not really doing any watch work because my apartment is being built and I can't set up my work space until the dust settles.  But it won't be much longer, I think.  Do you also work on Accutrons?  Glad to see a fellow Texan on here.  Happy watchmaking!
Shirley
I repaired a Accutron a year ago but I don't own one yet.  All of my own Bolova's have Swiss movements. So I still want a older American made movement Bolova.
Accutrons seem to fall victim to "free" battery changes. The one I fixed was a mess of corrosion from a busted gasket.
Here is my beat up and twice rebuilt Bolova.  I need to clean and overhaul the face and repaint the luminous points on it. This watch is my favorite and started my whole watch repair journey.
 A "free" battery change had damaged the gasket and filled the watch with water while swimming in 1999. A few years ago I found a book on fixing and building watches and this was my first repair.  It now it has a Ronda movement.
Welcome Sleeper. It,s a pity you had to replace the Bulova movement with a Ronda movement but unfortunately that is how the industry is shaping up with the restrictions and prices of parts. Many will be interested including myself how you repair the quartz / electronic watches.
This is a nice friendly forum with all levels of horology sharing their knowledge and sometimes even their mishaps !!!!!!
Anyway enjoy the forum.,
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
