I joined last summer but before I could post much I was in a car accident and injured my right hand.  Once I recovered enough to be able to both type and work on my watches I had a back log of watches to repair. That along with my day job to keep me busy for a few months.  Now that I am caught up and healed up I can start posting.
I live In Texas near Dallas and repair watches as my second job.  I am a Electronics Engineer, Systems Engineer and Machinist.  Currently I am learning mechanical watch repair or I should say learning more about it.
I do repair quartz watch movements and electronic watches.  I have a few old LCD and LED watches. I also have a collection of Timex and Bulova watches.
Hey, Sleeper!
Welcome back.  Sorry to hear about your accident, but glad you're recovering.  I'm in Texas, too.  I am south of Houston in Pearland.  I have some vintage Bulova parts, if you ever get in a bind and need something.  At the moment I'm not really doing any watch work because my apartment is being built and I can't set up my work space until the dust settles.  But it won't be much longer, I think.  Do you also work on Accutrons?  Glad to see a fellow Texan on here.  Happy watchmaking!
Shirley
I repaired a Accutron a year ago but I don't own one yet.  All of my own Bolova's have Swiss movements. So I still want a older American made movement Bolova.
Accutrons seem to fall victim to "free" battery changes. The one I fixed was a mess of corrosion from a busted gasket.
Here is my beat up and twice rebuilt Bolova.  I need to clean and overhaul the face and repaint the luminous points on it. This watch is my favorite and started my whole watch repair journey.
 A "free" battery change had damaged the gasket and filled the watch with water while swimming in 1999. A few years ago I found a book on fixing and building watches and this was my first repair.  It now it has a Ronda movement.
Welcome Sleeper. It,s a pity you had to replace the Bulova movement with a Ronda movement but unfortunately that is how the industry is shaping up with the restrictions and prices of parts. Many will be interested including myself how you repair the quartz / electronic watches.
This is a nice friendly forum with all levels of horology sharing their knowledge and sometimes even their mishaps !!!!!!
Anyway enjoy the forum.,
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music.     Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero.
    • Good shout - I'll grab something like that and some around the required size from cousins too...
