Pith quality (and other pith related questions)
Halvis
I'm starting my journey into servicing watch movements and need to order some pithwood. I am ordering from Cousins, and have no experience with pith.
The indian pith is way cheaper than AF or Bergeon, and they are out of german. How much does the quality matter? Is the indian good enough, or should I go for the swiss?
Two other questions:
  1.  Sticks vs discs. Sticks seems more economical. Are there any reasons, besides convenience to go for discs? Are the sticks easy to cut?
  2.  Is there some sort of rule of thumb for how long a pith disc will last, or how often it should be changed?
Thank you!
Bergeon has branded pith wood?  :rolleyes:
I think I've given less thought to pith than any else when it comes to watch service.  I bought some cheap sticks that came from Atlanta if I remember correctly.  They'll last me for years and seem to do the job just fine.  I cut off a small disk and use it primarily to clean tools or hold oilers and needles when not in use.  They're a good place to set a balance wheel when you're not using it too.
Answers to your questions:
  1. Yes, sticks are pretty easy to cut
  2. They last a long time in my experience.  I change them out when the whim hits me.
Edited by RyMoeller
Forgot to answer the OP's question
Don't now why but never use pith wood. There are some small round ones on my oil cups i have used but for cleaning the oiler? Most of the time i clean the oiler in Rodico?
The pith wood never is on the table as it so light it always is somewhere else?
Edited by rogart63
I have both sticks indian and german, and I can see the difference. German ones are smooth and no particles failing from them, indian seems to be different, not so smooth and some small bits of wood comming off them. Im sure that paying more for german ones is worth as it save a lot of issues when this tiny bits of wood stick to your table or movement. Same is with bigger pieces of pithwood.
Sticks vs. round ones - both are needed for different purposes, sticks for cleaning small or hard to reach places and softer round ones or made of core pith wood are for pivots and other delicate parts.
Edited by Rafal
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
