movement ID help
Ok guys, just going through the box of bits and bobs and decided to get this cylinder escapement watch movement cleaned up and to see if I could get it running again, well I did and it does.
Question is who made the movement, as you can see it has D&G on show and a serial number, but if you lift off the barrel bridge you find the arrow logo of Felsa!
I have looked and looked for the D&G logo but to no avail, so here I am asking, unfortuantly I didn't take a picture of the arrow logo.
These movements are known as a five bar movement. I don't know the size of this one, but many are fitted into ladies Pocket watches, many come with decorated dials and are fitted into Swiss silver cases with a back and hand setting . As yours doesn't have that it could be smaller and comes from a wrist watch case, its still a five bar movement and were made in the millions.
Old hippy many thanks mate once again, this one measures 30mm in diameter and yes has a decorated enamel dial and gold hands, but sadly no case, will have to start scouring ebay to see if I can find one on the cheap to make this little watch a runner and whole again.
Glad I could help!
The only thing to mention is that you've said the movement is 30mm ... and that would put it at around the 13''' to 13.5''' size. Don't want you spending ages trying to locate a stem only to find that your watch is a scaled up version of the FHF 11''' and the stem you locate doesn't fit!
Firstly I am only a relative novice like you so any advice I give will only be based on the steps I'd logically take to try and arrive at an answer. There are folk on this forum with waaaaaay more experience than me. I can only hope to be as knowledgeable one day as the others who have already contributed to this thread.
The normal pain with trying to locate a stem is the need for the various 'interfaces' on the stem to work in perfect harmony with the sliding pinion, setting lever, yoke etc. However if you're working with a simpler stem wind and pin set then the stem doesn't need these kind of interfaces so you potentially have more tolerance in getting something generic. My observation on ligne size was just that it probably stands to reason that the stem for a pocket watch two whole ligne sizes larger than you think will also be larger(?).
I do concur however that your watch looks exactly like an FHF 11''' as per ranfft. As oldhippy mentions however this style of watch was made in great quantities (and ligne sizes) and also note that ranfft whilst being a fantastic resource does not list literally every movement ever made.
So anyway, back to your issue ... if you don't have the original (damaged) stem to take measurements from then you just need basic measurements of the overall length of stem you need and then the dimensions of the square section that fits into the winding pinion and approximate length. If you look through the listing against http://www.obsoletewatchandclockparts.com/401-winding-stem.htm you should find this gentleman has a pretty good selection of old pocket watch stems and if you ask him nicely he'll probably do his best to find a match with those measurements you'll give him.
An alternative - if you're likely to do this as an ongoing hobby - is to look out for a job lot of old stems. If you can get these at a reasonable price it could work out well e.g. if you get 30 stems and only 25% ever fit your watches this might still be more cost effective than getting separate stems with postage.
Just an idea and if so here's a relevant ebay search: http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_sop=1&_nkw=pocket+watch+stems&rt=nc&LH_Auction=1
Cheers mate, yes like you im a happy tinkerer, with help from a local "smith" that runs a horological workshop, anyway, yes I'm trying logical searches for a stem, my trouble is, is that I get an old movement like this and find Myself wanting to find a case for it etc etc and get it back to a fully working watch as it once was, bit like a dog with a bone I suppose haha.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
