Hello from Kansas
NMarsh
My names Nathan. Pretty new to the hobby as a whole. I recently inherited a few mechanical movements, which kind of sent me down this slippery slope of trying to fix watches. I am still early on in my learning, but I have gotten to the point I can take a working movement apart and put it back together and it still works. I have found so much useful information in this forum, I figured it was time for me to sign up and add a little content. I already have a million questions brewing, but I will save those for another post, if I can't dig up the answer on here first. I'll just go ahead and say thank you ahead of time to all those that take the time to add so much information to this site.
A little more about me outside of watches. I am a 3rd year medical student, still unsure of what I want to do with my life. You would think after 7 years of school I would have some idea what I want to do. Other than watches, I enjoy woodworking, fishing, and just about any other "meaningless" task to get my mind off of school. I am recently married, and together we have a boisterous little beagle named Lucy.
I appreciate the welcoming words.
@oldhippy do you primarily just work with mechanical clocks or do you also work with electrical? I have a beautiful Hammond Gregory "Skyscraper" circa 1930's. Unfortunately it looks like it is the 50htz version and not the 60 htz, so it will likely run a few minutes fast each day if my memory serves me right.
12 minutes ago, dadistic said:
Greetings and Salutations!
The fine motor skills developed by practicing horology could help with becoming a sturgeon surgeon.
Good luck!
Thank you for the warm welcome!
Surgery was an incredibly interesting rotation. I actually enjoyed it quite a bit. However, I didn't enjoy getting to the hospital at 0430 every morning and leaving at roughly 1800-1900 every evening. Maybe it was just because as a student we had do our clinical duties as well as still find time to study for our test, but that 2 months was the least I had slept in a long time. Not sure I could maintain that lifestyle for long.
Currently looking into Anesthesiology possibly. If not that, than I will likely do Internal medicine.
I retired a long time ago. i used to restore high grade clocks not electrical clocks, Longcase, bracket fusee, french clocks and complected movements, my apprenticeship was in all 7years I spent many years working on maniacal watches all types.
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how to do a remove the default 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
