Seiko westminster chimer strange issue
clockboy
My wife purchased a really nice wall clock. It has a quartz Seiko Westminster/Whittington chime movement and all works perfect until 9.0 am. It chimes 9 chimes @ 9.0am then at @ 9.07am it chimes 9 chimes again. It then is out of sequence by 7 mins & as yet I don,t know if it sorts itself out. Just by chance has anyone come across this issue. I suspect the answer will be a new movement. :mellow:
Just an update it appears it only does this between 9.0am & 9.45am. then goes back in sync at 10.00.am.
My knowledge with quartz is limited but I am guessing there is some sort of timing disc for the chimes & just this area is corrupted/dirty. I will not touch unless the fault develops. I am normally in my workshop or out by 9.00am anyway . :D
https://www.cousinsuk.com/product/strike-chime-with-pendulum-seiko
I am the same not a great lover of quartz BUT her who must be obeyed purchased it.B)
For those who do own one or purchase one the set up is after fitting a new battery it only chimes the hours for the first 90mins & then it is in sync and chimes on the 1/4's & 1/2 hours. Also @ 11.00pm it stops chiming  & starts again @ 5.45am.
The only issue with this movement is between 9.00am & 9.45am which is fault I can live with.
Hello CB
"The only issue with this movement is between 9.00am & 9.45am which is fault I can live with."
You have noticed it, talked about it, thought about getting it fixed, I reckon it's going to "tee" you off and get into your head then it will have a big accident involving you and a hammer when the better half is out for the night (:-))
OH will probably chip in and say it's the best thing for it (;-))
Cheers,
Vic
20 minutes ago, Vich said:
Hello CB
Cheers,
Vic
:D
Is there much paranormal activity in your house, I have noticed that my screwdrivers and tweezers keep moving from where I left them when I am tinkering with my watches, sometimes they dissappear totally and re-appear underneath something else.  When I complain my wife just looks at me and shakes her head and mutters something about "getting worse".
Cheers,
Vic
  • 6 months later...
  • 4 years later...
  • 2 years later...
Ok so I have one of these and it works for a while then starts to chime at 24 past and adds an hour to the chime sequence. Sometimes chimes at 38 past also and becomes more and more erratic with respect to odd chiming times. If I reset the chimes (by pressing the AM/PM chime buttons, it chimes the correct number the first hour then goes haywire again... I did leave the battery out for a while and when I started it again it behaved perfectly for about a week then started misbehaving again. A friend in IT suggested removing the battery and leaving it in the fridge over night... haven't tried that yet  - just turned the chime down so I cant hear it!
Hi these are wholly quartz / solid state devices battery controlled with some plastic gear work. The gears can be removed and cleaned  but the whole movement costs around £ 30 as a replacement. Will take around an hour to fit and is the cost effective answer.    I built a clock for my Brother with the Seiko movement several years ago still up and running.
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
