How Old?!? Not A Clock Mechanism As Such...
There is extensive information about this 2,000 year old "Computer" on the Internet,  it was used to track the planets, predict eclipses and show the time of the Olympic games,  not bad for 2,000 years ago.  It was another 1,000 years before anyone else managed a gear based mechanism of this complexity.  It is called the Antikythera Machine after the place where it was found,  about 100 years ago,  clever people the ancient Greeks.
I saw this some time ago and as Roger says there were some incredibly clever people back then. To be able to work out the the mathematics then actually manufacture a device as complicated is truly mind blowing. Even today it would be a massive, or should I say a mathive achievement.
  • 11 months later...
I just finished a book about the Antikythera Mechanism called "Decoding the Heavens" and tonight I re-watched a Nova episode about it.
Fascinating subject on its own, but also as it relates to clocks. In the book it says that early clocks in Europe incorporated astronomical displays that were "spookily similar to their ancient predecessors such as the Antikythera Mechanism" and "The speed with which these astronomical displays became so elaborate and so widespread - and their similarity to those developed by the Greeks - suggests that all this did not emerge from scratch. Various pieces of the necessary technology, and the idea of using gearwheels to simulate the heavens, must have been lying dormant in a range of devices - including water clocks and hand-driven calendars - so that when the invention of the escapement allowed the construction of a mechanical clock, all of these old tricks came rushing out of the wings into the new tradition."
One of the most interesting characters in the book is Michael Wright, who made a working model of the mechanism using hand tools such as would have been available in ancient Greece. In the Nova video you can see some old pocket watches in the background of his workshop.
https://youtu.be/4eUibFQKJqI
What I cannot figure out is how it was operated,  there is a knob on the side which when turned operates the gear train and moves the pointers.  To me it seems a bit like a wind up perpetual calendar watch in that if the watch is ever allowed to stop it will quickly be out of synch.  This means someone had the job of operating it the required amount everyday,  one can imagine the pointed fingers if ever they forgot.
If anyone can explain better how it was operated I would be very interested.
My brain is hurrting thinking about the machine, never mind what kept it running. Maybe they threw it in the sea because they couldn't biuld a driving mechanism (clock) that could hold accurate time!
  • 1 year later...
  • 1 year later...
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
