Rolex Real or Fake
18 hours ago, jdrichard said:
Canal Street?
Canal Street is in New York City, it's an area known for counterfeit and fakes of all kinds:
Reputation as hawkers' haven[edit]
Canal Street is a bustling commercial district, crowded with comparatively low-rent open storefronts, and street vendors to the west; banks and jewelry shops to the east. Canal Street is also the main Chinese jewelry business district of Chinatown.[6] Tourists as well as locals pack its sidewalks every day to frequent the open-air stalls and bare-bones stores selling items such as perfume, purses, hardware, and industrial plastics at low prices. Many of these goods are grey market imports and many notoriously counterfeit, with fake trademarked brand names on electronics, clothing and personal accessories (including the fake Rolex watches that have become a Manhattan cliché). Bootleg CDs and DVDs are common, and are offered for sale on Canal Street—often before they are even officially released in stores or the theater—in makeshift stands and suitcases or simply laid out on bedsheets.[7]
Widespread sale of these counterfeit goods persists along Canal Street and in its hidden back rooms despite frequent police raids.[8][9] In addition, legislation was proposed in 2013 to try to make purchasing counterfeit items a crime; this would let the city's economy earn back at least $1 billion annually in taxes.[7]
https://en.wikipedia.org/wiki/Canal_Street_(Manhattan)
On 12/30/2016 at 1:21 PM, MilTimeCan said:
Agreed !!! that little star on the rotor...most definitely Chinese.
I've had a fake Rolex open before and it also had a Chinese movement inside.  The amazing thing to me was that a replacement movement was available for a mere $30 US.  I'm still astounded that a fully jeweled movement can be produced at such a cost.
Which moment?
A mov.t like the above is $4 or so. I  buy complete watches to make small gifts, for less than $10.  I'll take them apart and post pictures when I have a chance.
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
