Thanks, Cousins also does have Hermle barrels. It might be the case that it is compatible with the Schatz barrel. Looking into that tonight. Getting the bushings from Cousins is also easy.
In the meantime I try to use the bell barrel for the clock to see if it makes a difference.
Before you go buy bushes or make them check the pivots to see if they are worn, if they are you will need to fix them first and them measure the diameter of the repaired pivots to make sure you don't end up with bushes that have a too large pivot hole.
I just mounted the bell barrel wheel instead of the regular (worn) barrel wheel. The clock does still not start. I cannot really believe that the play in the pivot hole is responsible for that.
Do you suggest that inserting bushes would help?
They certainly can cause a clock not to run. With worn bushes the wheel gears do not mesh correctly either too shallow or too deep. If not sure remove the barrel and just have the wheels installed and see if they spin freely.  I follow this guy a lot.  See how he re-bushes. You will not have the customised tools he has but he explains really well the techniques required to fit a bushing successfully.
I watched this video a few day ago, most of how he goes about the work is wrong, for starters you do not re-bush from the outside of the plate, you re-bush from inside, if you use the correct reamer it will automatically  find the center of the whole. To be fair to him I don't think he was well when he made this video, he is about to say rat tailed file and changes it to small file. He also says we are on the inside of the plate, we always put the bushing in from the inside of the plate, he is putting the bush in from the out side of the plate which is wrong, a bush has a slight taper, doing it his way the bush could easily work its way out of the plate. He calls the bush a broach, a broach is another name for a reamer, The way he pushes the bush in is the wrong way round he is pushing in the bush by the thickest end not the thinnest,  the proud of the bush should be on the outside and is taken down to form the  oil sink. After he has used the burr, he says we have got our oil sink, but its on the inside of the plate. He even tests the wheel to the new fitted bush from the wrong side of the plate. He starts to hand broach it from the wrong side, you do not broach from both sides, The pivot runs on the complete pivot, not on the high spot in the middle as he says, if it has a high spot it is barrel shaped and needs turning down,  A very very bad video indeed.:pulling-hair-out:
Thank you all. I lost faith in repairing the clock. It could as well be the case that there is more to repair. So I stop here, assemble the few parts I disassembled and sell it. In Germany we have a saying: don't throw good money after bad. I rather concentrate on more rewarding projects.
Source: http://www.woodentimes.com/PRIMUS/Primus.html
Just need some proper wood and start my CNC mill. Sounds more rewarding to me.
there is a lot of mistakes made re bushing a clock plate. i have a few clock that were bushed wrong and do not keep running.  i suspect that an elongated hole was not "re located properly" ,but, back to the spring barrel.   that double strike ships clock requires a  good deal of power from that spring barrel.  i think the spring barrel is the first thing to correct..
Wish I had not put the vid up now.!!!!!!!  The point I was trying to show was the importance of getting the hole for the new bushing in the correct position. I never spotted he was putting in the bush from the wrong side.
SORRY
Del
Thank you all. I am sure everyone who stumbles over this thread can learn something. And if it is how to not do it :biggrin:.
I have chosen to stop this. There are too many unknowns in this crappy movement. I learned a lot though! Thanks everyone.
Cheers Alexander
clockboy did you watch the video? I know he has been ill, so that's what I put it down to because in the past he has made some excellent videos. I think I even recommended his videos here on this forum.
Yes he had Sciatica and could not walk with it. However he had an operation to put it right. I should have paid more attention I hang my head in shame. :)
I had a final look at the clock. After powering off the mainspring I removed the escapement which was relatively simple. I then powered up again and it stuck again. No movement whatsoever.
I then took a pegwood and forced the pivot of the barrel adjacent wheel down in order to move to the other end of the elongated hole. And the wheels started moving! I was able to reproduce this behavior on several occasions. I may look into re-bushing only this pivot hold. My concern is that I am not able to drill it right, i.e. the drill finds its way towards the wrong end.
Any ideas?
Cheers Alexander
Any ideas?
Cheers Alexander
Your would do better with a reamer rather than a drill
Sent from my SM-T585 using Tapatalk
Sorry don,t agree control of a drill is difficult as it will tend to drift.I give this advise from bitter experience, my advice for what it's worth is use a reamer
Again thank you all.
I was torn between repairing and selling. I eventually decided to assemble the clock and sell it on ebay. I don't have the proper tooks to get it done right. I still have my 7733 waiting for service as the next challenge. I'd rather service / restore another old watch from the 60ies before.
I learned a lot from this:
  1. These 70ies Schatz Clocks had a better reputation (at least to me) than they deserve. The one I got must be considered crap.
  2. Repairing clocks is yet another story compared to watches.
  3. I need proper tools to get the job done the way I'd like to (the right way).
  4. Clocks have a significant wear if the material is poor and need quite some machining. You just don't know in advance if you're as inexperienced as I am.
Since the only thing that I don't have enough, is time, I'll stick with watches.
Cheers Alexander
15 hours ago, vinn3 said:
a drill will do a good job if used properly.    it is essential to "control feed and speed" - etc..
Anyone who is just starting out on clock repairs should never use any type of machinery on a clock. Irreparable damage can be caused in a flash, in all my years as a clockmaker I never ever drilled the plate to re-bush. Hand held reamers is the only safe way to re-bush as I have said that way you have complete control, if you follow the correct procedure nothing can go wrong, you take your time with the repair, also you yourself can feel the cut and you will be aware of how much the reamer is cutting a machine can’t, the difference in the type of brass is phenomenal. I have worked on many high value clocks and you won’t believe how hard the brass can be, some will even take the edge of a reamer and the brass just splinters away. A machine drill can be very handy in a work shop but for re-bushing don’t even think about it. Not even one with a slow feed control.
Edited by oldhippy
Just a little more to add to what I said in my previous post.
The brass used in antique clocks and I’m talking about clocks after 1900 but before. You might find a description that says it has never been repaired, that is not luck that is because it was made of top quality brass and steel both were much harder than today. That would apply to the spring wound or fusee wound clocks. Weight driven clocks are wonderful but they all have a common fault and that is the weights, when the clock has some wear and tear the clock is forced to carry on working, that’s why it is common to find a lot of damage in weight driven clocks, in particular the 8-day Long Case or Grandfather clock, yes they are the same. Re-bushing and worn pivots are the main problem with these, worn teeth also occur but not too often. 30 hour Long Case movements nearly everything will be worn that is because people do not wind them correctly they just pull on the chain, you are meant to take the weight yourself and pull on the chain this prevents wear and tear in the movement. I hope you find this helpful.
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
