I started my watch repair hobby about 8 months ago, got my desk setup and started buying non-running watches off of Ebay. Now I have literally a pile of running watches that are ugly but keep good time.
Wondering what most do with the watches that they get running.
Just ordered a #1000 Timegrapher, so I can spend time going through the running movements and get them as close as possible but after that don't know what to do with them.
I actually did consider giving them out at Christmas. Nothing anyone would want to wear but the fact I repaired them would be the nice thing about it. All of the movements are very nice, just the case and dials are less than desirable. All keep very good time.
Wonder what the postage to Romania would be??:biggrin:
Probably be able to break even if I sell them on Ebay, but like oldhippy said I could use that money to buy tools.
More than likely will keep them, may try to find nicer cases and dials for some of the nicer movements and wear them.
Would you not come across a nice watch that has a broken movement? I have a Cronel that needs a 8800 movement, the running watch is worthless but I like it.
I would keep them as they won't eat anything and will take up very little space, the fickle world of fashion may make them collectable?
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
