I got this old movement quite cheap over ebay. The stem is broken and needs replacement. The watch is barely running when fully wound. There is a lot friction in the system.
The dial sais "CHRONOMETRE IAXA". There are no markings on the movement besides "Déposé" which seems to mean something like "patent pending". Not sure who made this movement. There are so many movements out on the market that it is very difficult to identify the caliber. It is not important anyway. This is just for practice.
This time I wanted to disassemble the mainspring, clean it, lubricate it and assemble it. This went pretty well. I used Moebius 8212, the only one I have.
Next was the barrel bridge. I already mounted the barrel bridge but forgot to put the center wheel in place first.
On the last picture you can clearly see the wear of the crown wheel teeth tips.
Edited by AlexanderB
Next: escape wheel. Here too it proved to be a challenge to mount the escape wheel bridge. I found this to be more difficult compared to fine swiss watch movements, like the ETA 2472 or others I was working on. The bridge is too heavy to allow it to be placed gently. It took several approaches to get this job done.
Finally got it done including the pallet lever with its bridge.
I then finished the dial side.
The movement is running quite well. It develops huge differences depending on the position. But the beat error is below 1ms. Amplitude is well above 220°.
I consider this a success. Too bad the stem is broken (got the movement like this).
17 hours ago, AlexanderB said:
Next was the barrel bridge. I already mounted the barrel bridge but forgot to put the center wheel in place first. IMG_1491.jpg
Those marks on the edge of the barrel are telling me that the arbor is not or was not upright. It can happen by worn out bushings or if the barrel bridge is not placed back correctly. The edge of the barrel was sticking to the bridge cousing winding hard. This also explaining the marks on the crown wheel teeth and the broken stem.
Excellent pictures and presentation ;)
Edited by szbalogh
Thanks for pointing this out I completely missed that when I first looked at the photos, but once pointed out its very obvious.
Its tips like this on things to look out for that are very helpful for someone like me just starting out.
Thank you @szbalogh! That makes absolutely sense to me. I totally overlooked this important sign. This is why it makes sense to publish this on this forum. It would not have occurred to me. I'll keep that in mind.
I am now finished with it. Here is what the timegrapher told me
BEFORE (Dial down)
Beat error 0.7ms
Angle 135°
+320s/d
AFTER (Dial down)
Beat error 0.5ms
Angle 270°
+100s/d
Here are a few more pictures. Some of them are merely for the sake of taking the pictures. I love crawling inside the movement with my huge DSLR :)
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
