Hello from Colorado
JackW
Hi,
I was recently told about this forum, from a person I bought a watch and is apparently active here... I started working on watches while I was trying to get a PhD in Geology. Ended with my masters, a good job in my chosen field and a hobby that is both fascinating, zen-like and frustrating...  I think is equal parts. Regardless, I've been building up a skill set for about 6 years now. I got into it because as a grad student I could no longer afford to have a watch maker do repairs... So I bought tools and sought out bargain watches.
I mostly seem to work on Swiss movements and am good with Gruen's movements from the Aegler Rebberg ca. 1920 to the cal 405/420 series of the 1940s. But work on Tavannes/Cyma, Omega, Longines, and a raft of others. I've a collection of about 30 or so watches and have sold or traded away about twice that at this point. Recently I've been into trench style watches and have 4 sitting on my bench. A Fulton Watch Company (with an A. Schild 13''' cal 137, a sterling cased Waltham and a pair of war-time Elgins) but also an early Gruen Curvex.
Images attached are of a vintage Elgin I tackled earlier this year. Some American movements are a dream to work on.... others not so.
Cheers!
Welcome Jack. I speak from experience it is not just "American movements are a dream to work on.... others not so". But for me & many others this is the fun, fascination with horology. Also there is the never ending learning curve that just hooks you in. Enjoy the forum.
Welcome JackW, you hit the nail on the head with that statement. Looks like you made it over a few hurdles to get where you're at, meaning: you have made the investment in tools and researched your projects well, this is the place for friendly, honest advice. Good job on the Elgin!
Jack;   very nice pix.,   i have the same watch mvt..  cad101 dated the watch imediatly !  that shows the real value of a forum.  on the subject " American made"  here is my experience:  the first pocket  watch i "opened" was a cylindar escapement and pin set. it was pre 1900 acording to a watchmaker ?.  fortunatly,  i opened an elgin and continued collecting.    vinn
14 hours ago, JackW said:
Hey there!
Thank you for the warm welcome.
dadistic... what part of Chicago? I lived in Logan Square for 6 years before moving to CO. Uptown before that....
Currently in Berwyn, but lived in Logan Square in my youth. We have family in Edwards Colorado, lucky for us they are right close to skiing :-)
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
