I'm really interested in finding out what main characteristics in a mechanical watch decide how much power reserve one can achieve. Can an existing watch be retro-fitted to enhance power reserve and is it recommended? I'm thinking does it impact on the other components in a watch?
That is an interesting question. The length of the spring determines how long the watch will run (power reserve). I have fitted springs that are just a bit longer than the original because the original size was not available with no issues. The strength is a more complex matter. In my opinion for hand wind watches having a slightly stronger strength spring than the original should not cause any issues. However for auto wind watches this could cause issues as the barrel/spring is just being wound via an oscillating weight.
Fitting weaker springs could cause lower amplitude. This is certainly an issue with clocks. I have replaced many tired clock springs that have just lost their effectiveness,so I dare say the same applies to watches.
The watch movement is designed in a way to run and work with a certain type of mainspring which is height width and strength. Any other mainspring fitted could cause all sorts of damage and effect to parts that make up the movement and the time keeping.
Thank you for the replies, yes I fully understand that it may be possible to make some minor refinements (especially on hand wound watches) however one probably cannot get away with making drastic changes to for example doubling power reserve from 40hrs to 90hrs simply by retro-fitting a mainspring and a new barrel even if it was possible to obtain one with equivalent dimensions. I was intrigued by the recent purchase of a system 51 Swatch automatic with a power reserve of 90 hrs compared to one of my Omegas. The Swatch barrel does however look somewhat larger.
First, one has to consider the characteristic of the spring. The next diagram shows the spring force compared to winding angle (red lines, original spring). The new spring should have the same peak force (blue line) as the old one not to overstrain the gears.
The geometry of the barrel hovewer determines the spring length.
General rule according to DeCarle: Practical watch adjusting is to have 1/3 space for the spring couils, 1/3 open and 1/3 for the barrel arbor.
Coil number of the spring (possible winding angle) can be increased only if the spring material is thinner.
I can imagine that there are a newer and more modern spring steels those have the same strength but are thinner than old ones. But the problem is that we have even trouble to find original or similar springs to our watches. To find the required one for this problem seems impossible. And even if there is a source one need to shape the spring to fit in the barrel (make both end hooks). I dont think it worth the time to have +10-30 % more power reserve.
On the other hand, manual wound watches are designed to wound every day at the same time. And by knowing your watch and with a daily routine they can be made incredibly accurate since the spring force changing every day the same amount.
You beat me to it szbalogh I was just going through this last night at my watch repair course so its all thresh in my mind
But to just add a bit more there are formulas that go into it deeper
For example to work out the correct length of the spring is
length = Pi(inner radius of barrel squared - radius of the barrel arbor) / 2 * thickness of mainspring.
On average the thickness of the spring is around 1/100th of the inner barrel diameter.
A very simple check you can do to see if the spring in the barrel is the correct one and not just one some hack found and stuck in is check the k factor.
The k factor is the ratio between he radius of the barrel arbor core and the thickness of the mainspring. This usually falls between 10 and 14
k = radius of barrel arbor / thickness of the mainspring
Bottom line, the spring in the barrel will be the best spring for the watch unless some hack has fitted an incorrect spring at some point.
That's what I was told many years ago 1 third for spring, 1 third for arbor and 1 third for space.
Just noticed a mistake in my formula, corrected formula below
length = Pi(inner radius of barrel squared - radius of the barrel arbor squared) / 2 * thickness of mainspring.
I'm just now going though the section on mainsprings on Daniels's book. Fascinating stuff. Despite all the calculations there's no good way to determine which spring the watch will need when designing one other than some rough rules of thumb.
It's way more technical than I need but fascinating for sure and highly recommended.
  • Similar Content
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
