My next project is to prepare another spindle to be able to make snailing pattern on movement plates and wheels. I will try to replicate Steffen Pahlows demonstration.
https://www.youtube.com/watch?v=S_S8oA9HdlY
Currently i have one ER20 collet spindle driven by a regulated car fan DC motor that is exellent for turning parts in wax collets. My plan is to prepare another of such DC motor for the other spindle.
Here is a picture with the DC motor disassembled and ready for cleaning. You can notice that i have already cleaned the commutator.
Next is to turn a grinding attachment with a cylindrical grinding face mounted on the shaft of the second motor with set screw(s).
This type of thing is rear these days. Many old Pocket watches and wrist watches would have such a thing done. Its merely a decorative thing that is pleasing to the eye.
Yes, i think it so as well. It would be nice being able to do such thing :)
But i was wondering how Waltham and Elgin wavy patterns were made? They look so beautiful!
Like my daughter does it with a spirograph game.
Edited by szbalogh
At about 5 minutes and 50 seconds into the video below they show finishing the plates then how the girl puts decoration on and even one of the templates they used.
https://www.youtube.com/watch?v=ys4ChOWYNy8
In the next links they show a variety of techniques and you learn some new terminology like GENEVA WAVES (COTES DE GENEVE) and CIRCULAR GRAINING (PERLAGE)
http://www.thehourlounge.com/en/vacheron-constantin-articles/movement-finish-true-mark-haute-horlogerie-557275
http://www.watchwow.com/2013/09/110008/basics-of-movement-finishing?page=2#.V9hSrIJ0-70
Then a different technique which unfortunately uses a really expensive machine but does produce interesting results. Plus from time to time she runs classes with the machines she has.
https://mechanicalcurios.com/2016/02/15/photos-from-engine-turning-ii-class/
First try on a simple washer. It was not flat so flattened a bit on a whetstone, hence the radial scratches.
I was using chromium powder (Cr2O3) in oil. It has some fine grain. The snailing pattern is definately there but i need more coar.se paste and need to try grinder with different diameters and speeds.
Edited by szbalogh
You always amaze me with your simple and easy ways to get a job done just think what you could do with a real lathe nice work.
Once again Szbalogh I am awestruck by your ability to achieve amazing results using the most basic of set ups.
Innovation, imagination, and a "can do" approach winning over expensive kit once again, you are an inspiration.
Thanks for the video.:thumbsu::bow::bow::thumbsu:
Szbalogh, I think with the correct speed and course grit you are going to get the correct finish.  I really enjoy watching your approach to things, you remind me of my father, who virtually never got stuck on any job due to his innovative ways. Keep up the good work!
Really interesting work and a demonstration of what can be done with whatever resources are available. Looking forward to the work on the Roskopf.
Cheers,
Vic
Winding wheel on the wax chuck after grinding the pattern. It has the paste on it, but here one can clearly see the lines grinded in the material.
Washed with paint solvent:
Here is the retaining washer after finished grinding:
And in the movement with a blued screw :)
From a distance:
Tomorrow i will make a two stage pattern on the  ratchet wheel.
Looking good eh? :)
But lets take a closer look! Notice the part close to the middle was not grinded. I was not grinding long/deep enough. The grinder did not touch this part of the wheel. I missed this before started grinding the external circle.
I could start the grinding again but it will do in this watch, since the wheel is mounted with a plate hiding that part.
  • 2 months later...
Szbalogh,
Do you live in a part of the world where you are surrounded by watchmakers? You have a clear picture in your mind of what you want done to the watch and then work out the procedure to achieve that goal. Your degree of focus and innovation has to come from somewhere. The work itself is amazing but watching the machinery you are using moves it up to extraordinary.
david
  • 4 months later...
Добрый день. подскажите пожалуйста, какую пасту вы используете,и делаете ли наклон , для получения рисунка
Good afternoon.  Tell me which pasta you use, and whether you are tilting to get  Drawing
Я использую алмазную пасту из Китая. Это 1-2 USD / 10gram. Долговечность. Да, я наклоняю две оси.
I use diamond paste from China.  This is 1-2 USD / 10gram.  Durability.  Yes, I cant two axles.
Guys, I would appreciate if you could translate your post into English before posting.  It allows others to appreciate what is being discussed.  Thanks Geo!
Haha i cant speak russian, used google as well :)
    • The tiniest screws are usually ones used to hold down cap jewels or Geneva stud holders in small high end calibers. 0.30mm threads are sometimes seen here. Smaller than that I've only seen on really small balance screws. I've made 0.25mm thread balance screws; that required making an adjustable die with a 0.30 tap. I asked my tap supplier if they had a 0.25 tap as they didn't list one, and they said yes, then called back to say they do but they are reserved for one specific customer. I think that customer must be Nivarox. Luckily 0.30 and 0.25 have the same thread pitch.   Waltham made some amazing automatic cam operated lathes already back in the late 1800s, really the first of their type and the origin of the term "screw machine" which became what all cam operated lathes were called- up until the Swiss innovated with lathes where the workpiece itself moved, sliding in the headstock collet. These are called a- wait for it- Swiss Lathe.   Die is 8mm diameter like the old standard dies (which are no longer made, at least good ones).
    • The part you've linked above is the 242 canon pinion. the 227 3.55 high is on Cousins as you've shown but isn't listed when you do a parts search for the 2892.A2 If you're measuring 3.6 then I think this would be the correct one as your original post.
    • It's this one, though weirdly the part code on the link ends 'h315' rather than the 'h355' it actually says on the site, tying in with the height of 3.55mm   https://www.cousinsuk.com/product/eta-2892a2?code=ETA2892A2242H315#   https://www.cousinsuk.com/product/eta-2892a2?code=ETA2892A2242H315# I note that dimension 'C' is given as pivot end to pivot end.
    • The rolex...the rivets made to brake away easily, probably what you saw happening with the Horia tool. It's not just about bending the balance wheel arms , which seems to be what these accessories prevent. Potential staff hole deformation....over one or many staff changes. Then we have Chronoglide popping out staffs with a staking set and proudly showing a wobbly wheel. ?? Removing the staff is just one part of the process of replacement. Staking on a new one is just as easy if not more so to mess up.
    • I was in London recently and took the chance to visit the Clockmakers Museum which is now hosted at the Science Museum. It’s free and well worth a visit if you are in that neck of the woods.  One of the exhibits was this screw made by Waltham. The blurb says you can fit 47,000 of them in a thimble 😵‍💫 I assume it was used in a watch and they didn’t just make it because they could. It made me wonder though, how on earth anyone could work on something that small. You can “see” it in the centre of the box in the picture; although you can’t really tell what it is. For all I know they cut a grain of sand in a half and put that in the box!
