Omega lume hazard ?
Hi all,
A neighbour of mine brought this Omega to me to look at, he's worn it for work and it looks like it's suffered some heavy shocks.
On first examination it looks like the stem is bent as when you turn the crown the whole movement waves backwards and forwards in the case, also the minute hand has moved up the shaft and is fouling the second hand stopping the watch, it will restart if you move the hand out of the way, I also noticed some of the luminous markers are flaking away and lying around on the dial.
As it is marked  '' Swiss T ''  I'm assuming this is tritium and my question is ; will this be a hazard if I open the watch & are there special procedures for cleaning it up ?
many thanks, Phil.
T Swiss Made T is often on the dials of watches, and I doubt it means Tritium, as Tritium is actually a Gas, normally contained in small glass tubes, and is a fairly recent innovation, brought out Long after this Omega was made....
I doubt your lume has any major hazard but I wouldn't sniff at the dust!
Edited by Alastair
These have a split stem which you pull to remove. Obviously use a crystal lift to remove the crystal as it's a front-loader. There's a trick to popping the movement out; you may need to carefully rotate the movement to a certain spot to let it pop out.
Edited by rodabod
Thanks rodabod that's really helpful as I've not worked on one of these before,
& thanks to all others for your replies.
As I don't yet have a crystal lift I've had look on Cousins site, they have two, the Bergeon at £65 or the Indian version £11.95.
I just wondered if the cheap one is a waste of time or if anyone has used one with success.
You should ask the seller if the elastic is still in good shape on these.  I have ordered two off Ebay recently that the arms flop around uselessly on.  I have yet to find a good replacement and rubber bands don't seem to last very long.
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
