Problem Getting Balance to Spin Freely
The root of my problem is with an old Waltham Full Plate pocket watch. I cleaned it and when I lowered the balance into place it would not always spin free. This I thought that I need more end-shake with the jewels so I added paper to the balance cock plate and , although free, still will not tick. There was a moment when it did spin nicely and I have not found that position again. Any suggestions on what to do ? I know there is enough power in the wheel train so that is not the problem. I did remove and clean the jewels so that is not the problem.58a235a6b362e0ce7b21eb9276a290c2.jpg0845b6681c338ac5efd2c5020db8815e.jpg5f8ff127cb7c4353d7c68c1660d3c269.jpg
be shure the jewels are  seated properly. i have had problems with installing the same cock and balance.  the jewel on the front plate (under the dial) was loose  and the  pallet fork was hard to line up.   not as easy as the more modern pocket watch.  vinn
Seems like it's all about alignment
Is the pallet fork snapping from side to side when a little pressure is applied. And as clockboy says it may be way out of beat check the jewel is between the banking pins and how much did you have to adjust the banking pins even a small amount can throw the movement way out.
i like the suggestion: "let down the main spring,  remove the balance and fork,  wind it just enough to make the gears spin"".   all gears make at least one revolution.  start over from there.  beware the setting of the banking pins.  vinn
Good suggestion on the jewel position. If it is not in the Center, then I will need to take spring off the balance I guess.
Thanks Vin, I will try this technique and check that he fork snaps back an forth between the banking pins
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
