Alternative to a staking tool set
TimFitz
I ultrasonic cleaned them a few at a time to get rid of crud and dirt then put each one in a hand held drill and cleaned them with very fine grit wet and dry paper then each one with wire wool. The punch ends  which had a flat polished surface I left I only polished the shafts . Took me about a week to do the whole lot.
Just received my K&D staking set from EBAY its not to pretty now , but using the great ideas for everyone here, I have started to clean everything up.It is not missing any parts & I'm pleased.
The cleaning is going well however two of the holes in the die plate are plugged, with balance staff parts I would imagine. I bought a cheap set or tiny drill bits that instantly broke.
Any good suggestions on how to unclog these?
Again thank you all for the advice on buying and cleaning ,I wouldn't have got it correct without your help.
I took before pictures and will post them with the after pictures when done.
On 8/21/2016 at 9:47 PM, tomcolson said:
I started out using only abrasives to clean up the stakes as described here. Currently (today in fact!) I start with an overnight soak in EvapoRust to remove most of the rust and convert what's left to black iron oxide. Then I use fine 3M radial bristle disks to polish up the working and marked ends. I take great care with the working ends to insure that I do not round over corners, etc. Usually the highly polished working ends are the least rusted parts of the stakes.
Awesome page! I enjoyed reading it.
1 hour ago, tmac1956 said:
All:
This is probably the best reference that I've found for the Inverto tool series. You can get either the hard cover or paperback reprint from lulu.com
http://www.lulu.com/shop/archie-perkins/the-watchmakers-staking-tool/hardcover/product-22409846.html
I hope this will help someone as much as it did me.
Tom
I'll second this recommendation...the clearest descriptions I've found of how to perform many useful task using a staking set.
The book also contains a reprint of a 1986 K&D catalog, but if that's all you need you can download it for free from kanddinverto.weebly.com.
Here is the after photo waiting for the dome
21 minutes ago, TimFitz said:
I have to know, Whats JG Hall?
Inventor of the staking tool in the mid 19th century when, if it was worth making, it was worth decorating. His early tools were black enameled and decorated with bands of gold decorative motifs (Greek key and the like).
Thanks, I thought it was something like that
On 8/30/2016 at 11:53 AM, TimFitz said:
The plating and paint were both falling off so the rust cleaning removed the rest. Perhaps black enamel would be nice? what do you think?
I'm partial to the light green that some of the old Star and Boley sets are painted. But black enamel would look very nice too.
5 hours ago, TimFitz said:
Here is my finished $45.00 K&D staking set all cleaned up & the new glass dome arrived today. All finished.
Now back to watch repairing.
The only thing I'm missing is the centering punch, I have tried all the usual places recommended from all the websites. I will eventually I'll find one. If anyone knows where I can pick one up please let me know. Thanks
Very stylish indeed. :thumbsu: The dome adds a nice touch and the overall package just screams old time watch maker. Keep an eye on uncle larrys site as he has stakes come up all the time. Looks like many years of use left in the old girl yet. As far as paint goes have a look into getting it powder coated, way nicer shine and super hard. We used to have our hydraulic jacks done and it would amaze me how many home projects came back with the shop work lol
Dave's Watch Parts has a  Marshall centering stake. Not sure if it will fit,  but worth a shot.
http://www.daveswatchparts.com/StakingTools.html
40 minutes ago, Cad101 said:
That's a nice set now it looks shiny and new. It's amazing what a little hard work can achieve well done.:thumbsu:
Thanks, I remember you said in a post, to keep looking & one would turn up. You were correct. $40.00 for tool $13.00 for very thick glass dome. Thanks for your help.
PS. hard to believe the before and after pictures?
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
