Congrats. Looks like it has good amplitude, but can you take pics on the timegrapher or equivalent application? That will tell if the watch is running properly.
Edited by jdm
Ah there's nothing like your first. Good job my man keep it up it looks to be running well. Do you own a timegrapher yet it will help a lot with regulating and help with fault finding. But with the amount of oil you bought I should let your funds replenish unless of course money is no object in which case get one ordered:D
Thanks everyone. Yeah. Those oil disasters always take time to recover from. :) Going to have to wait a bit on a timegrapher. Note to self: Google timegrapher. :)
Great job! Remember to buy the timegrapher, the staking tool set, the jeweling set and the escapement tester. Do not waste your money on cheap, disreputable tools, buy witschi, Bergeon, Seitz, and Bergeon respectively....It is only a few dollars...like US$10K....more?
PS. I have to make a living somehow, remember to tell them I sent you!!! :D
Cheers,
Bob
PS2. No, seriously, great job and just have fun!!
I remember my first one: I was so happy then, I threw away my only time keeping devise I had before: a solar alarm clock. You know, the one with the blade sticking up...in the garden... always making this sound in the morning: cock-a-doodle-doo, oh well! :D
Sometimes not having a timegrapher is a blessing. It's fine if you trying to find/diagnose the problem but you will waste a lot of time trying to nail down that last bit of accuracy..getting it perfect. Most watches run ok enough. Give or take a minute or two a day.
A watch would have been a good runner 40 years ago but there will be wear and you have to accept that unless you are prepared to change all the wheels other stuff. Positional accuracy is especially tough to get right.
Sometimes ignorance is bliss.
Anil
Congratulations from me as well, I stripped and reassembled my bro in laws watch as my first, it was not so much excitement as sheer relief that it worked, it was just gummed up really and needed a service. I was lucky it kept good time as well.
I have since acquired the timegrapher and spent quite a bit on tools as well but sometimes I just like to look at them and clean them a bit - oh dear that sounds  weird, but tools are great.
Cheers,
Vic
Edited by Vich
Forgot why I did it
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
