You guys are making fun of a watch that is special on so many levels, come on, you never had a watch for sinning!
The watch make iss Forsining  so if you wear it you can sin all you like I'm getting one so I can rob a bank and afford a better watch:D
I remember a few years back someone posted a 'franken' Omega which had both sweep seconds as well as centre seconds. All using original parts. The website was about how to spot fake/franken Omegas. Cant find a link back to it as its been a few years.
Anil
Yep, it's a sin to spend money in crap...at least this crap tell time...or tries! :)
Good name: For-sin-(n)-ing!!! Well spotted!
Cheers,
Bob
1 hour ago, svorkoetter said:
Wouldn't it be safer for the watch if you took it off while sinning?
Never, sinning would be over!!! :)
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
