Just received yet another good buy on a 21 jewel movement and the roller jewel is missing, I think. Any advise on sourcing this and the installation technique. I think I need some shellac.c1af63a9f8e5df6b2845e7b4574cc49a.jpg
new jewels are quite expensive, and you get 3 of them in the package if I remember correctly. I would start to check first part number you need for this model, and then try ebay. Im not illinois expert, but Im sure there are factory catalogs with part numbers, easy to find, or you could go for new one but thats require some measurements to be taken before purchase. Sometime you can get new old stock for reasonable price. Regarding shelac, you would need dewaxed one - there are 2 types available. Regarding how to install - Fred's book explain it, with illustrations.
Can you glue in a roller jewel? I understand shellac is the standard for this operation , however, with today's glues, there must be a replacement! As well, what is the technique. This is my first shot at this operation and I know I will be covered in shellac by the end of it. Can I use a soldering iron to heat up the shellac? How do I get the jewel and the shellac in the hole. Sorry for the novice questions .
Sent from my GT-N5110 using Tapatalk
Glue would work BUT if any real- positioning is required then you will be snookered . The quickest way is normally the correct way
to warm roller table you can use this tool:
http://www.ebay.co.uk/itm/Pallet-Fork-Warming-Tool-with-wood-handle-out-of-a-Watchmakers-Estate-/371644636975?hash=item5687bf1f2f:g:cTgAAOSwboVXOhS5
you can find it for about 8-10$, I just pasted first Ive found. This is also called combination tool, it has some more uses :) than just roller jewel.
How to prepare shelack for jewel installation please see this video:
https://www.youtube.com/watch?v=TY28dap5Zqg
I would not advise glue as well, shelack give you chance to manipulate jewel or replace it easily, glue could be kind of permanent solution...
Procedure you could find in henry fried watch repairer's manual
Roller jewels are either round or half round (having one flat face). Can't be sure, but from the photo it looks like you need one with a flat face. If you can't find the exact part number, you can use a jewel gauge like this:
http://www.ebay.com/itm/VINTAGE-WATCHMAKER-ROLLER-JEWEL-GAUGE-SWISS-MADE-SV498-/191838117461?hash=item2caa715e55:g:ty8AAOSwBnVW-zsH
You use the gauge on the fork of the lever to determine the correct width of the jewel. You want a good fit, with a little play. The height of the jewel is important as well - when installing you don't want it to interfere with the safety action / guard pin.
I totally agree that shellac is the right approach due to its adjustability - you can warm it up just a tad and then fine tune the jewel placement which will almost certainly be required if this is your first time.
The tool referenced above is great for holding the roller table - and it is used to gently heat the roller - you apply the heat to the tail of the tool - indirectly heating the roller. You typically place a small dab of shellac on the brass tool itself to judge when the heat is sufficient - the dab will melt.
There are also a number of devices that can be used to hold the jewel itself in place / vertical while setting.Do a google search for "roller jewel setting tool". They also appear from time to time on ebay. I also just checked uncle larry's http://www.execulink.com/~lfoord/tools.html
He has a gauge and a setter available now. Let us know how it goes!
Actually I have small amount of roller jewels, so if you have size I can look for it, and if you lucky I will have it and can send it to you. For double roller they are marked "short" because of guard pin on palet fork - it has to be shorter than single roller ones. Ive got set of vials with roller jewels, but only some is with something inside :(.
4 hours ago, jdrichard said:
Sorry, no link attached Geo
Now sorted JD.
Is it possible to use the heat from a soldering iron to melt the shellac? I also have these sticky part pick-er-upper tool for picking up very small parts. I could use this to hold the jewel. I would need to create my own technique. I may need to get the Guage set to properly source the part.
You should certainly not apply heat directly to the roller as you can damage it. In Mark's video he uses a simple brass bar - something you can pick up for a few dollars. I suppose you could use the soldering iron to heat the brass - but that doesn't seem too efficient. You can either pick up a cheap alcohol (spirit) lamp or even use a pocket lighter to heat the brass.
As far as the gauge - you can use some assorted solid copper electrical wire to find the correct size. If you know the wire gauge, you then know the diameter which should be enough to source a jewel. Can't hurt to try. If you have a micrometer or caliper set you can use any wire or pin and measure that.
Brilliant advice. I do have a micrometer. I would simply find the right fit and then measure the wire. I really don't want to remove the hairspring, so I may hold the unit in a piece of pith wood in a vice for stability.
Well that's a whole other story :(
You shouldn't need to remove the hairspring from the balance - BUT you should remove the roller from the balance! For one thing, especially given this is your first time, you don't want the shellac to foul the balance or staff. When it melts it gets drawn into the jewel hole and comes out the other side. You can see this clearly in Mark's video above. Placing the roller flat on a piece of brass also has the benefit that the jewel will be flush with the back of the roller table automatically. You can pick up a roller remover very cheap and that's a tool that's worth having. There are many styles. I prefer this:
Also - be aware that some double rollers are actually two piece doubles which require 2 operations to remove correctly. You also need a proper staking tool to replace the roller (and in the case of a 2 piece - the safety roller)
Just now, sstakoff said:
Ugh!
Well, it seems crazy for the first look :) Shellac is also used to mount parts on the lathe. I found that hotlgue is perfect for the same pusrpose. Maybe it does the job for pallet and roller jewels as well, just a theory. Please note that I am an inexperienced hobbyst and dont have shellac neither the repair currently that need it.
For balance assembly weight is very imoprtant, so using hot glue may affect that and change way it works. Same as too much shelac.
Wysłane z mojego GT-I9505 przy użyciu Tapatalka
I now have the tool, the jewel and the shellac. I now need to know how to hold the roller table with the tool? As well, do I need to remove the roller table from the balance shaft. I know I need to remove the hairspring.
You have a bimetallic heat-compensation balance which supposed to compensate some degrees of temperature change. I dont know but i can imagine that the high temperature needed for shellack may hurt the bimetallic joint. I wouldnt take off the roller table if its a simple balance.
Or You use hot glue or nail polish :startle::D
Use shellack it does not need a lot of heat to melt. I presume you are removing the hairspring & roller table from the balance.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
