watch ticking but hands moving slowly
I am assuming that the seconds hand is ticking normally, but the hour and minute hands are either not moving at all or are losing time erratically.
If this is the case then one of the most common causes is a loose canon pinion. Another symptom of this is a lack of any resistance at the crown when you set the time.
Note: your movement appears to be an AS calibre. I can't tell which one but it looks to be something like a 1950/51 family. AS movements don't always have the canon pinion where you think it should be and the 1950/51 use an off set arrangement with the canon pinion sitting between the setting wheel and the minute wheel.
Marc I think your right about the cal and cannon pinion. Its such along time ago with me I'd forgotten, my brain cells are now working and am I right in thinking the cannon pinion is very short and is difficult to tighten.
thanks for the reply I think it's an AS ST 1902/03 I can't remember off the top of my head, when I pull the stem out to set the time it feels fine, they do move but really slowly.
Just to clarify your last statement - when you say "they do move but really slowly".... Are you also saying that they move relatively slow when you use the crown to set the time??
Regardless - it would seem that your issue lies somewhere in the motion work - cannon pinion, minute wheel, hour wheel,... If the tension on the cannon pinion is good, I'd check the alignment of mesh of all these components under the dial...
when setting the time all seems normal, but in reality 15 mins in normal time the minute hand moves only 2 mins if that makes sense.
Ok so this is a common problem with a AS1900-1906 movement  it has a friction pinion on he intermediate wheel which needs tightening see this thread ive had to replace a couple of them managed to tighten one they are available from cussons
thanks
OH on a side note the same friction pinion is used in the 1904,1906 ,1914,1916 ,2064,2066 and 2164,2166  so if you have any parts movements lying about doing nothing use it as a donor.
I don't have any can you still get part's for this.
Yep find caliber number and cussons have the parts or troll the bay for non working AS movements but there's no guarantee the friction pinion won't be shot on those either cussons would probably be your best bet.
thanks mate :thumbsu:
9 hours ago, rogart63 said:
Could have some old movement laying around here somewhere? Send me a PM and i should take a look tomorrow. Maybe even a NOS part?  Needs to take a nap first :)
Thanks rogart63 when I get back from my cruise in 2 weeks I will strip it down and have a look what is going on,it's a 1802/03
thanks
Had three old AS 1950 but in everyone of them they had taken the cannon pinion. So i guess the it's a common problem. Have more parts and take a look if i find something. Cruise a little for me also :)
thanks mate:D
    • I voted.for the 6.99 assuming £, which works out to $8.74US at the current exchange rate.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
