Staking sets.
Having watched most of Mark's brilliant videos, I was intriuged in the 'Replacing a balance staff' one to see a staking set being used. As I have recently aquired a set, I wondered if a short tutorial video on the uses and methods employed using a staking set could be made. I beleive the canon pinion can be replaced using a staking set, which would be useful to me as twice when I have tried to replace a canon pinion, all that happened was the arbour/staff pushed out of the centre wheel. Good job they were scrapper movements for practice! Hope I have posted this in the right place......
You should only need thumb pressure to refit the canon pinion Rog are you using a hammer on the stake ? Also support the centre wheel from the back , I usually have the train bridge in place and the movement on a flat solid surface then push the pinion on with the stake using just finger pressure. Did use tweezers once but snapped off the centre wheel pivot  so lesson learnt .
I am still trying to figure out if I need a staking set. What are they most used for in watch repair? Sorry for the stupidity but I have not had the occasion to use one yet, however, as I get more into old pocket watches, I know I may find a use. Advise?
Sent from my GT-N5110 using Tapatalk
Mostly for balance staff replacement, since old pocket watches have ususally broken pinions. But for a simple service of a helathy watch, its not necessary. Although, it could e used fot fitting hands and canon pinion for example. I neither have the tool, but have some balances for staff replacement. FIrst i will try to make it with custom made stakes and anvil.
Thanks for the note
Replacing the cannon pinon I never used a Staking set. I would remove the minute wheel, place the cannon pinon over the center wheel turn my tweezers over and use the the flat side at the very top and press down. Job done.
  • Like 5
Thanks for the useful replies....that link is very good, Don.
Andy, this happened before I got my staking set, and no hammers were involved...:DI was using tweezers,but must have been a bit over enthusiastic...still, never mind, it's all part of the learning curve...must try your method of putting the bridge back in place. I've got several more old scrappers to practice on.....B)
Edited by RogertheDodger
In my mind jewels need a jeweling tool, -- there is usually a micrometer for depth travel involved too -- sometimes staking sets have this attachments...otherwise I don't thing that a regular staking tool is convenient for the job since you are usually whacking something with a hammer...jewels don't like that!
Cheers,
Bob
    • @HectorLooimakes an excellent point, the degree should be brilliant and more than useful but if it's not recognised, then the job options are limited.  You need to find out how many companies are willing to accept Mechrotronics.
    • Hi other than testing the coil without the proper tools it will be difficult.  If you +an rig up an external supply and attach it to the cut block you may be able to pick up the pulses on the chip if not on the coil. i have attached the parts sheet for the watch 9362 which gives you the part number of the cut board assembly, whether this part is still available or not , who knows. ETA 9360, 9361, 9362.pdf
    • Hi and welcome. First of all, check the power reserve. If the watch is runing, this means the spring is attached to the barrel arbor. If there is no end of winding, this probably means that the spring is not attached to the barreland it's outer end is slipping. In such case, the watch will run, but the power reserve will be small - about several hours
    • Hi welcome to the forum. One can only reiterate the diagnosis already made by clockboy mainspring problem. But before tearing it to pieces take a little time to read the attached file to acquaint yourself with all the various parts. TZIllustratedGlossary.pdf
    • We think about these preps as "one-dips" partly because they are terrific solvents but also because the parts they are used on are often cleaner in general than many other parts. But old oils petrify, and even something like B-Dip can't clean up over-soiled parts without some extra effort, as mentioned above. There is an intermediate step during cleaning where the solvent can partially dissolve tarry residues so they have a more liquid varnish-like consistency, and that could well be what you are seeing on the coils after two washes. I wouldn't worry that your B-Dip was contaminated before you used it on this hairspring, but it I wouldn't re-use that aliquot AFTER this cleaning!
