Hi guys, just joined in to this wonderful forum. After looking at watches online and watch repair on on the Tube I got hooked, being a mechanic / technician
I just love the little gears and levers and stuff, how can they ever make it so small ?? Anyway I got a cheap Caravelle at the flee market , took it apart and now
I'm re-assembling . Then, I'll do it again just to get a feel for it.
I'm sure I'll find a lot of info on here , looking forward to it.
Cheers
Hello and welcome to this friendly forum. Plenty on here for beginners and advanced. It might be a god start for you to practice taking apart and the putting together pocket watches there a lot bigger and in many of them the movements are very similar to manual wind watches.
Thanks guys, I guess I have to explore this forum and see what's where to find. Is there a watches for sale section, or
parts , are there any vintage Mido collectors? There you have it, first questions are out !
Welcome Kopke hope you enjoy the forum lots here for all levels. No question to small or trivial from this knowledgeable & friendly forum. Enjoy
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
