7750 headache
HI all!
I have this weird problem with a watch I built for a friend, he told me to build it using an Asian 7750. I didn't want to, but oh well, I went and bought the "latest" version of the A7750 hi-beat, etc..
I finish the watch (first I took the movement apart and did a cleaning/rebuild/oiling). Aside from the parts being "flimsy" it wasn't out of the ordinary ...
It looks GREAT on the timegrapher (0.0s, great amplitude, ~ +2 secs/day) , yes, I did set the lift angle to 49 deg.
BUT the watch actually runs incredibly fast, it is gaining about 1/2 hour every 10 hours (!) . I did demagnetize it just in case but it didn't help.
Am I missing something?
My guess would be that the hairspring is touching something or even sticking to itself.  Check to see if it is true and the spring action is clean.
Edited by jeffc83
WOW!
Thanks for all responses, yes, a disassembly is on the works, escapement is perfect, and as mata said, I suspect the canon pinion might be the culprit. I am 85% confident (yes, I quantify my confidence) that I installed an ETA canon pinion, and doing math I see that there is an extra tooth somewhere ... time to pull the microscope :pulling-hair-out:. Of course, it won't happen until Friday...I am xtra busy for the next two days ..
On hindsight I should have pushed my friend to spend a little more and let me get an ETA ... well, practice makes perfect ....
43 minutes ago, jdm said:
Christian is a top notch watchmaker and one can only learn big time from his way of thinking and doing.
Thats a fantastic link, @jdm. I've read several overhaul "stories" from this guy. They're very useful as references because of the knowledge base, and the guy also takes excellent pictures. Great methodology.
JC
I'm not saying it's not the canon pinion, but I was  suspecting one wheel in the wheel train. If it were the canon pinion, then the error in timekeeping would be much bigger.
Edited by matabog
This is correct...and when its the cannon pinion it would likely be losing time.
JC
Thanks!
Yes, I will inspect every wheel in the train ... I used a few ETA parts on the build, so there are a few suspects ...
Will report back when I find the culprit. (perhaps the second wheel, that is the one in the wheel train that I replaced for an eta version (!))
    • Either of those ideas might work. Did you try putting a thin layer of rodico on the cocktail and then push the screw through it. Afterwards, soak in one dip
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
