HI all!
I have this weird problem with a watch I built for a friend, he told me to build it using an Asian 7750. I didn't want to, but oh well, I went and bought the "latest" version of the A7750 hi-beat, etc..
I finish the watch (first I took the movement apart and did a cleaning/rebuild/oiling). Aside from the parts being "flimsy" it wasn't out of the ordinary ...
It looks GREAT on the timegrapher (0.0s, great amplitude, ~ +2 secs/day) , yes, I did set the lift angle to 49 deg.
BUT the watch actually runs incredibly fast, it is gaining about 1/2 hour every 10 hours (!) . I did demagnetize it just in case but it didn't help.
Am I missing something?
My guess would be that the hairspring is touching something or even sticking to itself.  Check to see if it is true and the spring action is clean.
Edited by jeffc83
check the wheels and pinions teeth number and their ratios. calcul
Edited by matabog
WOW!
Thanks for all responses, yes, a disassembly is on the works, escapement is perfect, and as mata said, I suspect the canon pinion might be the culprit. I am 85% confident (yes, I quantify my confidence) that I installed an ETA canon pinion, and doing math I see that there is an extra tooth somewhere ... time to pull the microscope :pulling-hair-out:. Of course, it won't happen until Friday...I am xtra busy for the next two days ..
On hindsight I should have pushed my friend to spend a little more and let me get an ETA ... well, practice makes perfect ....
43 minutes ago, jdm said:
Christian is a top notch watchmaker and one can only learn big time from his way of thinking and doing.
Thats a fantastic link, @jdm. I've read several overhaul "stories" from this guy. They're very useful as references because of the knowledge base, and the guy also takes excellent pictures. Great methodology.
JC
I'm not saying it's not the canon pinion, but I was  suspecting one wheel in the wheel train. If it were the canon pinion, then the error in timekeeping would be much bigger.
Edited by matabog
This is correct...and when its the cannon pinion it would likely be losing time.
JC
Thanks!
Yes, I will inspect every wheel in the train ... I used a few ETA parts on the build, so there are a few suspects ...
Will report back when I find the culprit. (perhaps the second wheel, that is the one in the wheel train that I replaced for an eta version (!))
Nothing yet!
I will do the disassemble/reassemble tomorrow or Saturday ...WAY too busy with "regular" work (the one that pays the bills :( )until tomorrow
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
