I did a complete refurb of a vintage Seiko Pogue with one exception. I did not clean the hairspring or the balance pivot jewel. The amplitude does not look good and the watch is running fast. Any advice on a simple way of cleaning the hairspring? I know I would need to remove the balance cock and I think I can clean the jewel. Will this make the amplitude better (most likely yes)
Another question. Can I simply use naphtha or lighter fluid and dip the hairspring in it. And if so for how long do I dip it in?
Your video is in slow motion, correct ?
Yes, you can use lighter fluid. Dip it in, swirl it around GENTLY, for a minute or so maybe ?
The jewel hole is also very part. A sharp piece of pegwood would help.
Video is in slow motion. Will do as you suggest. Should I throw in the balance cock with the hair spring. Jewel in?
Yes, you don't need to remove the hairspring from the cock.
I'd remove the jewel too (don't loose it !!!!) ;) (been there done that...)
I'd remove the jewel too (don't loose it !!!!) [emoji6] (been there done that...)
So. Remove the jewel, unscrew the balance cock and remove it with hair spring. Swish the complete unit in lighter fluid for 1 min. Let dry (should take a few minutes). Clean the lower jewel hole, clean and oil the main jewel. Oil the lower jewel hole 9010. Reinstall the balance cock. Oil the balance jewel, reinstall the jewel. Job complete.
Does this process look good ?
Swish gently ;) you don't want to end up with a tangled up hairspring...
If you have a small blower you can use it to speed up the drying. If not, air drying is fine.
34 minutes ago, jdrichard said:
[snip] clean and oil the main jewel. Oil the lower jewel hole snip]
I assume "main jewel" is the lower jewel, right? You only oil the lower jewel once ;) (I'm pretty sure it's a typo, but I'd feel bad not pointing it out)
Swish gently [emoji6] you don't want to end up with a tangled up hairspring...
I assume "main jewel" is the lower jewel, right? You only oil the lower jewel once [emoji6] (I'm pretty sure it's a typo, but I'd feel bad not pointing it out)
Not the top jewel? The one that is by the adjustment leavers ?
Yes you do that too. I understand what you mean now!!
...except, what is the balance jewel ? There are only 2 jewel holes you clean : the upper one (on the cock) and the lower one (on the main plate)
Here is my attempt at fixing your steps :
So. Remove the jewel, unscrew the balance cock and remove it with hair spring. Swish the complete unit in lighter fluid for 1 min. Let dry (should take a few minutes). Clean and oil the lower jewel, reinstall the balance cock. Oil the upper jewel, reinstall the jewel. Job complete.
If amplitude is still not good after that, it might mean that your balance is not getting enough power...
Low amplitude coupled with a fast rate are classic symptoms of sticky hair spring coils.
Frenchie's advice is spot on; remove the upper jewels to improve the circulation of cleaning fluid around the pivot and jewel surfaces, and clean the balance and cock, and jewels in naphtha. The naphtha will not affect the shellac on the impulse jewel so you can leave it in for a reasonable amount of time without any ill effect, I'd give it about 5 minutes. If you swirl it around then only do so very gently; a safer approach to agitation is to use a blower to gently blow bubbles through the hair spring.
When you take it out place it on absorbent tissue and use your blower to dry it all thoroughly before reassembling and oiling.
Don't forget to demag as magnetism is just as much a cause for sticky hair springs as contamination.
Once it is back together carefully inspect the hair spring for flatness and for clearance with the underside of the cock. If it is touching either the balance wheel arms or the underside of the cock you will still get poor amplitude and an increased rate.
Good luck.
Timegrapher pictures?
Have you demagnetized the whole watch?
No I have not d magnetized the watch as I currently do not have a demagnetizer. Any suggestions on this purchase?
Good luck.
Mark. Thank you for taking the time to respond to my problem. I will use your advise and frenchies as well. I will need to purchase a demagnetizer unless there is another way of unaligning ferrous material.
You need that as well a timegrapher. Otherwise you can't do watch repairs or maintenance.
Demagnetized and fully assembled and regulated. Works ok. It was a rusted mess so I shall see if it continues to operate over the next few daysc89dfeed3f8665b8d895081bf3a0c241.jpg
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
