Rolex GMT 1675 stops , crown comes out.
Guys, I fixed the crown, I simply pushed the clutch inside the crown and then pinched the outer part with tongs (pliers, whatever it's called), now it has less spring action but at least it won't split from the clutch and I can pull it out to set the date with no problem.
Edited by chriz74
So, awkward situation here. The new original stem arrived and it's longer than the one that was originally fitted.
Now I am asking myself, should I use the old one or try to cut the new one and take the risk to ruin it?
... I made the stupidest thing. Cut the new one without trying it before and now even if it's the same length as the old one for some reason it wouldn't hold the first position, the winding position like if it was too short. Could it be that the old one was not screwed completely?
update: So after cutting the damn stem I tried like this, put the threadlocker on it then screw the crown only half and let it rest for some minutes. Then I installed the whole thing and now I can set the time and wind the watch. Sometimes the stem disengages from the winding mechanism, don't know why. Anyway the watch was not running so I touched the balance wheel and it started to run, now it's running. I put it on the winder to monitor the behavior and see if it stops again.
I don't know if the stem solution was the best thing to do, probably not, but it kind of worked and I don't want to spend 25 euros for a new stem right now, not before seeing what happens.
Edited by chriz74
Please measure distance E. Seems different to me.
No, it's the photo angle, it seemed to me too but looking closely they are the same. This is an original rolex 7869 stem. Besides I ended up putting the old one.
Edited by chriz74
Here we go, after 49 hours on the winder I found the watch stopped. I moved it a bit and started moving again. Now I stopped the winder to see when it will stop again, the problem doesn't seem related to the automatic winding. Maybe there's something, some debris that is stopping the movement?
Edited by chriz74
If the watch is stopping and starting I would say it needs at least a clean. As for the stem it could be a matter that dirt has got under a part and is causing the problem, or the old stem has worn somewhere on the shoulders.  You say it does the same with the new stem so there might be wear around the entrance for the stem to go into or it could be dirt, does the stem wiggle around when the stem is in the winding position and in the setting of the hands position, if yes is the answer to one or both this can be fixed by a pro who knows what he is doing but it is very hard.
Regarding fitting the stem, Hippy is correct regarding cleanliness of the crown and pendant tube.  Once you ensure all is spotless, have a read of this article on stem fitting
You will find a post specifically on screw down crowns later in the article.
Took the watch to the guy that originally made the servicing. He said he had to lubricate the invertors of the automatic device. He added something about Rolex telling these don't need lubrication but he thinks differently. Let's see if the watch will stop again.
5 hours ago, chriz74 said:
Watch stopped again. Invertors are not the cause.
What on earth are invertors. To me it sounds as if he doesn't know what he is talking about. Is he qualified to undertake Rolex repairs.
I think it's referring to the mechanism that takes care of rotor change of direction.
6 hours ago, clockboy said:
Normally when a watch keeps stopping then the watch just needs a complete service & clean. I would personally take the watch to another watch repairer for a second opinion.
I would do as clockboy has said.
This morning I wound it manually and put it on a winder. Let's see if it stops. I'm thinking maybe yesterday stopped because after getting it back I didn't wound it and had it only for 3 Hours the day before on arm.
Watch stopped again after 48 hours being on the winder. I suspect the rotor is maybe slightly touching the caseback hence not winding correctly. So now I unscrewed the back as much as possible, gave 4 wounds and put it back on the winder. Let's see if it stops.
    • Hello, I am just starting to learn how to hopefully service mechanical watchs Right now I started by acquiring a bunch of tools and a first practice movement (ST36).  Since I got it last week I have been practicing disassembling and reassembling it (I don't yet have the tools and products for washing and lubrication as I estimated that the first step is the manipulation required for assembly and disassembly). To be quite honest the result have been interesting.  My first step was breaking the setting lever screw when I was trying to remove the stem (OK practice movement won't be able to set time, oh well). I did manage to mostly disassemble the movement (I kept the balance together, didn't open the barrel and didn't remove any jewels). I messed up the balance spring a bit when removing the balance (I think the impulse jewel was still in the fork or something). There was  a small tangle. I reassembled everything and surprise the movement came back to life. I disassembled it again and decided I will try to fix the hairspring.  So with lots of trouble I removed it from the balance and when trying to fix it I made more of a mess.  After reinstalling everything the balance won't oscillate (likely the spring rubbing on things, either the plate or the cock). Right now I wait for my second st36 and continue practicing while slowly buying what I need to wash parts and lubricate them.   Any of you think there is a chance I can repair that spring or find a balance complete for that movement which will cost less than the whole movement?
    • Hello, I am a software engineer and all day spent in front of my computer makes me want to do something more manual as a hobby. I like the mix of intricacies and basic technology of mechanical watches, the fact that such marvel could be built manually hundred of years ago fascinates me.  So I decided to combine the two and learn "watchmaking"  (between quote as I don't expect to ever be able to make a watch). My first goal is to be able to service a mechanical watch. My current status is that I am pretty good at breaking small parts in watch movements
    • Nothing special to the horological world, but this is my travel watch. For whatever reason, this watch has accompanied me through airport security more often than my appendix and gall bladder. I feel as if i need this with me as much as my passport.
    • Apologies for digging up an old post but I am thinking about doing the same. Can I ask the OP what medium he used on the wheel. Was it a sanding disc and polish and if so what grades. Thanks.
