Locked escape wheel.
This just in...
I found that when I tweaked the escape wheel with a pin, it freed itself from the pallet, so although the upper jewel in the wheel bridge looked okay, on closer inspection it seemed to move, and when I pushed gently on it, it virtually crumbled and fell out.
I think the jewel is 1.1mm dia and have found one in another watch in my spares box, so since I have nothing to lose really I am going to try to replace the jewel. I don't have the right tools so I will work out a safe way to perform the job. Wish me luck!
The back-up plan will be to find another wheel train bridge. Yours in trepidation,
Frank.
Latest on the Vostok 2414: have found a jewel in my spares box, managed to remove it from bridge and have fitted it into the wheel train bridge of the Vostok and it looks pretty good. Going to have a well-earned beer and see if it will run when I refit the bridge tomorrow! I'll have to check for end shake. I really think my Vostok will live again.
Frank.
I see old hippy,s point one of the pallet stones does not look to be seated correctly. If so it will never escape.
If it does not work with either the new or old escape wheel then this is the fault. To adjust the stone position you will need a pallet folk tool, heat & shellac. A pic below is the tool I use.
The story so far:
Since I don't have the facilities for resetting the pallet stone, I risked sanding a few 'thou' off the stone using 1500 grade paper (the Tamiya stuff I use for models). I managed to do this without disturbing the pallet stone, and hooray, the escape wheel advances as it should with a few winds on the mainspring. With the balance fitted, it really wants to go, but I think the beat corrector is not set correctly. So now I will do a little research on this. I am convinced this watch will go, it just takes perseverance. (Quite easy with the rain beating down outside!)
This is probably a first Frank, :startle: I wait with interest to hear how good the end result is.
Best of luck Frank you have identified the fault but I will be most surprised if the sanding down method will work as the tolerances are fine to say the least. If it was me I would find another pallet unit & fit.
11 hours ago, fjseal said:
The story so far:
I can't believe this. Why not just order another pair of pallets, you are making a lot of work for yourself  fjseal.
    • I bought a compass to detect magnetism. The magnetic tip reacted to both magenetised and non magnetised basic steel so it became a guessing game as to whether my test subject was either weakly magnetised or dense steel. I've found the best way to detect magnetism is by using the smallest unmagnetised screw and a known piece of unmagnetised steel to test the screw and another piece of known unmagnetised steel to test the first known piece of unmagnetised and another....................... 😂
    • Ha ha, reminds me of this: "Don't go puttin' none of that stuff on my sled, Clark. You know that metal plate in my head? I had to have it replaced, cause every time Catherine revved up the microwave I'd pi$$ my pants and forget who I was for a half hour or so. So over at the VA they had to replace it with plastic."
    • Hello and welcome to the forum. Added a little help for you . TZIllustratedGlossary.pdf
    • Hi @VWatchie - I have model of this Mondaine quartz watch in my collection, just a smaller size. I bought it many years ago, new.  I wonder if  the crystal on your watch is original?  My original crystal was entirely flat.  I scratched it at one stage and replaced it.  There is a dealer located in the UK who sells replacement crystals for Mondaine on the big E - I bought mine from him.  If you PM me, I’m happy to forward the listing details - he may keep different sizes for the Mondaine range?.  The replacement he sent to me was a perfect replacement for the original.   On a side note, the Ronda movement in these is very easy and fun to work on.  They’re also very cheap to replace.  I learnt a lot about the big date complication when the smaller date wheel spring mechanism malfunctioned and the date changing stopped. I stripped down the movement and it went back together very smoothly and continues to work perfectly.  I like the streamlined aesthetic of the Mondiane line.  I also have one of their big date mechanical movements which runs on an SW200-1. The crystal on that is also perfectly flat, btw.   Cheers, John
    • I have a DIY version, it’s a voice coil from a 300mb disc drive and a vdu transformer , when you put the tweezers in they vibrate like a tuning fork  and come out clean. Could get an engine block in.
