Tips for polishing hands etc..
DJT2
Hi guys, I've just finished my Hamilton 36000 restoration. I'm really happy how it has turned out apart from the hands & the metal work on the dial. The surface looks pitted, I've tried to clean etc but to no avail. I'd love to get some ideas on the best way to polish or restore hands etc..
Before
After
Dial hands & date window acd4eab4942050cb33f0c57e7859ec1b.jpgas you can see, they look pitted.
I'm interested in hearing what others do too.  I have had some bad luck trying to polish hands, turns out some hands are brass underneath the chrome, so instead of the expected solid stainless steel, things went south quickly.  As to your date window frame, I am guessing that is plastic, which has been chromed.
Ah yes, I never even considered the date window was plastic & I had a similar issue with polishing some hands to find they turned brass yellow. Had to replace them with a set of horotec jobs, which really detracted from the artdeco look of the watch.
The only thing to do is find new hands & replace. The cheap chrome effect will just peel off if attempting a polish.
Shame, thought as much. Other than Cousins, could you suggest a stockist that would sell a more varied selection of vintage style hands. Also, anywhere I could purchase dial date windows.
Found this some days ago? He polish the hands with some kind of plastic polish? Check under hand installing tool? http://www.thewatchmaker.com.cy/watch-repairs-video-tips.php
Wow great video, it amazed me how he could hold the hand whilst polishing with tweasers. I'd drop it for sure. But thanks it has really helped.
A couple of times I have used one of those tarnish removing cloths. They are nice and soft, although a little fluffy, and they have improved the look of dull hands etc.
Do you mean Cape Cod cloths?
I recently transplanted a dial and hands from an old case and movement (Vostok Komandirskie with 2414a hand-wind movement) to a new case and movement (Vostok Amphibia with 2416 auto movement). The hands looked similar to yours, and I was able to polish them using 5 micron lapping film (a bit finer than P2500 sandpaper), followed by 12000 grit MicroMesh (about 2 micron grit size). They ended up looking much better than before.
Edited by svorkoetter
Looks amazing. I've never used anything like lapping film, is it just the same usage as sandpaper?
Yes, it's basically extremely fine sandpaper, with a mylar instead of paper backing: http://www.leevalley.com/en/wood/page.aspx?p=33004
And this is the MicroMesh: http://www.leevalley.com/en/wood/page.aspx?p=62146
I bought a disc of the 12000x, and cut off small pieces to use on watch parts. I also have a full set of the foam-backed pads that I've used for a number of projects.
Brilliant, I'll order some now. Thanks
A while ago I bought some bergeon extra fine diamond polishing powder. I wasn't really sure what it was for & have never used it. Apparently I add it to a small amount of meths for extra fine polishing. Would this work?
To all:  Polywatch is a plastic polish BUT it is way overpriced for what it does.  Buy a tube of Simichrome and polish the plastic and/or crystal with that.  MUCH cheaper and it works on all metals as well.  Win win:D
Here in Sweden we use Häxan :) That witch in English :)
I think the problem with Simichrome is it is bit to harsh & thats why the guy in the vid uses a plastic polish.
Not sure why it would be too harsh though...the crystals come out fantastic, like new!  I have used both products many times (still have that polystuff too) but kept using the Simichrome instead because I ended up with the same result for a cheaper cost.  This is why I like being here, I just learned that I can use Häxan, provided I obtain it from outside the US;)  I also might learn that my crystals will MELT from the simichrome after 30 days, LOL :D
Edited by jeffc83
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
