Ridiculous Packaging
A certain well known on line sales company that shares its name with a place that has a well known rain forest are always getting mentioned for their packaging, mostly mine has been ok but then - I was puzzled when I saw the delivery man carrying a large box as I had not ordered anything that big. I ordered a couple of batteries from Amazon, packaged they are each approx 9 cm x 12.5 cm x 5 cm and they arrived today in a box 59 cm x 46 cm x 16 cm !
Amazing waste of resources in so many ways but they were delivered quickly.  I will of course recycle it.
Cheers,
Vic
As you said Vich, the key word is: Rain Forest. This is a special packaging in case the carrier -- who picks your item up from the warehouse 2 blocks from your house -- has to make a detour -- it is only a few thousand miles -- through the ubiquitous Rain Forest to deliver it, safely.
Quote: "It is because of the perennial rain occurring in that place -- therefore the name -- your valuable order may get...well "rained". The vacuum created between the actual merchandise and the exterior of the box will repel all of the insidious rain. The extra filling: read packaging material, mainly paper, will wick away all of the detestable moisture that usually accompanies the err, rain(?) ensuring your valuable order to be preserved in a pristine, un-wetted condition. Our research lab in the North Pole has found out that this is accurate. We are working hard with the postal service on a new mailbox design directed to enlarge the official mailbox specifications, and lobbying with the proper government authorities, to make its adoption mandatory. This huge and modified mailbox will be mandatory and used by the different communities/individuals around the world to ensure that our packages can fit. This action will guarantee us to meet our goal: total customer satisfaction. Sincerely,
P.O. THE Amazon In Chief :smiley-face-laughing:"
How about that for an explanation!!!
Cheers,
Bob
The reason why they use expansive packaging (yep..."expansive", not "expensive") with rechargeable batteries is because if they explode there is less compression around them to create a bigger blast.  A mostly empty box will absorb some of the hit from a blast, you see.  That's what I was told when I queried the delivery guy as to why my pack of AA Eneloops was packaged in a 30 x 30cm box from the "rainforest".
So, stroppy I believe you just hit the nail on the head! Based on Jeff's items experience I will assume, as a general rule, "the smaller the product the bigger the bang therefore the box is chosen proportionally...bigger!" :)
PS. Just having fun here!
i can identify with this. i work for a company that delivers it's own items. the guys that package the items use absolutely no discretion when it comes to packing a box. i've delivered boxes that i can hardly lift, while on the same order, there will be a box packed exactly like the OP's box above. ridiculous.
Just as an addendum,
When I folded all the packing paper inside the box up to go in the recycling, I weighed  it.   The weight was 1.5 times the weight of one of the batteries and if the large box was then included then the packaging weighed far more than the product.
The batteries were both packes in their small tough thick cardboard boxes and inside the small box the battery was protected in the usual shock proof blown plastic insert - immovable and safe as you could want.
Cheers,
Vic
image.jpegHere's my experience of ridiculous packaging this week.  It was left by Hermes last week in this state, open at the end and no content.  I don't lay all the blame with the carrier, if the company I purchased the goods from had even run a bit of tape length wise it would never have burst.
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
    • When can you use a standard crystal to replace one that had a tension ring? The first time I popped a crystal with a tension ring out of a watch I found that I had a suitable sized standard crystal and decided to try that.  It fit nicely and it was hard to see that anything was missing from the watch.  I understand that it probably reduced the water resistance of the watch but since it was an old dress watch it wasn't going for a swim anyway! I have since tried the same thing on another watch and found that the tension ring seemed to have an additional role of holding the dial in place.  With the standard crystal in there the dial and movement falls forward. This means it rattles in the case and falls forward and the hands fowl on the crystal (when the dial is down). Is there a trick I am missing here or does this watch require a special crystal?  I am reluctant to buy an expensive armoured crystal only to find I have the same problem.
