Lost Screws
I bought a nice little round box with different kinds of screws from Redrosteruk on Ebay . Since then i have bought some more to complement the box from Cousinsuk and have put the screws from movement i have taken parts from. All end up in this box.
That's a good way of building up your spare screws. What I also had was an A to Z of draws all sectioned with covers for old watch movements so I could also go to the the draw and see if I had screws for that movement or a part that I required.
    • Back home...printing now.  Will report results
