Hell friends,
I have recently purchased a Tudor North Flag. It is COSC certified. On my time grapher it runs from -6 to -2 in the six different positions. That is a total of 4 seconds a day
total variation if I am correct. I get a 2 ms beat error. So, my question is this, is this an acceptable range and just a speed error or should I take it in and have it adjusted?
Thank you and I look forward to your opinions.
P.S. This is my first COSC watch. I mostly have Steinhart's.
I would leave it. Who is to say your time grapher just might not be calibrated to such a high standard. COSC certified is more refined to a bog standard timing machine which most watch makers/ repairers have in their workshop
If the beat error is 2ms not 0.2ms then it is out of an acceptable range. The acceptable range is 0.4 ms or lower. Although the watch will run without adjustment.
I found this for you.
What's Minus4Plus6.com
The name Minus 4 PLUS 6 is derived from the Contrôle Officiel Suisse des Chronomtres (COSC) standard deviation rate of -4 to +6 seconds within a 24 hour day, tested over a ten day period of chronometer testing, in five positions and at three temperatures. Watches that are within -4 to +6 seconds deviation in a 24 hour period are awarded Official Chronometer Certification by COSC and the movement is engraved with a chronometer serial number. Rolex has a self-imposed stricter standard of -1 to +5 seconds per day and hence the designation, "Superlative Chronometer Officially Certified" on the dial of any COSC certified Rolex watch.
With 86,400 seconds in a 24 hour period (31,536,000 sec/year), a difference of +3 seconds per day is a deviation of 0.000035 (thirty five millionths) of a 24 hour run resulting in 99.99% accuracy. A Rolex watch balance oscillates at a frequency of 28,800 times per hour, - equivalent to a car going 87 mph, and traveling a distance of 3,600 miles a year.
I forget what the official chronometer tolerance is, and google isn't being helpful, am I right in saying it's -5/+5 seconds in 24 hours?
Anyway to answer the question, -4s is very accurate, chronometers can be more accurate than that but in reality the margin is totally unnoticeable in actual practicality,  and no mechanical watch, Chronometer or otherwise will ever be perfect. I don't personally see this as being worth adjusting.
Edited by Ishima
did i read somewhere that since seiko wasn't allowed to play in the swiss chronometer games, they took their marbles and went home - only to make tougher standards for their certified watches?
No I won't. I was just trying to find out if my Tudor was in the right place.
No, sir, not in the right place, you need to send it to my home address...then it will be in the right place! :D
I love Tudors too!! It's a great watch, just use it and enjoy it!
Cheers,
Bob
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
