Hi
I need to clean the bottom plate - specifically where I crammed in Rodico where I shouldn't have on the cap jewel assembly - as well as the cap jewels and Novodiac spring.
After cleaning, should I oil all the wheel train jewels with 9010 as well as the flat side of the cap jewel before reassembly?
Thank you muchly for your expertise...
Dave
Hi Dave, this will let you see what oils should be used. There are symbols at each point if lubrication and a list if what these lubricants are at the top left of the chart.
post-124-0-57969400-1455247711_thumb.jpe
Geo, thanks a lot, that is perfect.
At my age you can't trust the memory and it's always good to have a record to refer to.  :D
Much appreciated, Mike
Thank you for putting it in GD's. For some reason they restrict access to the ETA 6497 site. No idea why - it's not exactly step by step directions for making something nefarious.
Dave
I find that trying to follow the funny droplets on the drawing while reassembly is too cumbersome, and causes too much switching from an oiler to another.
For this reason I try to rationalize the process preparing a list of each point that gets the same type of oil, going to from thicker to the lighter, is the direction of motion. E.g. I did this for the Seiko 6R15 walk-throughout that I wrote.
I think that reduces the chances of mistakes, saves time, and helps understanding the use of the different oil types.
Edited by jdm
Anyone have a technical reference manual for a Farrari Lap Time Swiss ISA 9001/1300 movement?
From Canada
Best way to get results for new questions is to start a new discussion with your request in the title.
http://www.phfactor.net/wtf/ISA/9001-1300.pdf
http://www.isaswiss.com/fr/informations-techniques.html
Then for everyone else for the original question here's a walk-through.
http://www.eta.ch/swisslab/6497/6947.html
Thank you John, you saved me saying it. If I was able to lift individual posts and start a new thread I would, but unfortunately I can't. Also posting different requests within a post, makes searching for information a nightmare.
Did any one succeeded downloading PDF from ETA site?
I have a local copy downloaded few months ago when stared reading about different movements.
Let me check
Sent from my XT1068 using Tapatalk
I succeeded I pushing the cap jewel assembly out of the bottom plate. Does anyone have any tricks to make sure it is located properly...flush.
I think I should make a video too show people what they should avoid.
Dave
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
