Two New Projects
Two of the watches donated to me by family members are actually working, but I think they need servicing.
One is a small ladies watch, a Certina:
post-1596-0-23381000-1452015866_thumb.jppost-1596-0-01811600-1452015876_thumb.jp
The other is another ladies watch, maybe originally a pocket watch due to the position of the crown. It has a small button at 1 0'clock which activates hands setting. It has a double-hinged case back as well as a hinged front. The adjustment mechanism for the hairspring seems to be way out of position:
post-1596-0-04800500-1452016019_thumb.jppost-1596-0-74998800-1452016027_thumb.jp
post-1596-0-79602200-1452016035_thumb.jppost-1596-0-64936100-1452016043_thumb.jp
post-1596-0-48836400-1452016048_thumb.jppost-1596-0-11616200-1452016058_thumb.jp
post-1596-0-84243700-1452016061_thumb.jp
As I'm a complete novice in the art of servicing watches I ask you:
Is it too ambitious a project?
Are there specific matters I should be aware of (apart from not loosing parts or breaking Incablock-springs...)?
Is the Certina especially difficult because of its size?
Do I need special tools?
I have another more straightforward watch to service first, a lovely little mens watch which I hope to present to you when its finished.
Looking forward to your wise replies.
Pauli
Hi Pauli,
I would start on big movements first but if you feel confident tackling a small ladies one, go ahead! Now that certina doesn't have incabloc protection. As a matter of fact it was probably made before incabloc became main stream. So be careful not to drop it, it is not shock protected! Being that small, pivots among other delicate parts should be special care items...specially when lifting/setting down bridges. Also, being such small size, the proper oil should be an issue. Try to get the service data if possible.
Cheers,
Bob
Start with something that has no value to you, grab an old Timex with a pin/lever movement, Should be able to pick one up for a couple of bucks or at the dump. :D
They look cheap and simple but they can be a real **BLEEP** to get back together, after them a Seiko or Swiss seems easy, be assured you will wreck at least 1 watch whilst you are learning and it is less stressful if it isn't your grail.
Max
Your comments are appreciated.
Luckily I have two larger watches with Swiss movements (small second hand) I can practice on, and I think I will look for something cheap on ebay as suggested.
The process of working with watches is for me the most important thing right now on my learning curve but of course the result counts as well - It would be nice if the watch works afterwards  :lolu:
One of the two displayed watches has a cylinder escapement I think, do you know of any guide to servicing and lubricating such a thing?
Pauli
Definitely start on cheap throw away watches. Normally I work on pocket watches but finding cheap ones these days are getting more hard to find. The second watch may of started as a pocket watch, try looking around the lugs to see if their is any crude soldering. It may be an early wristlet and has value and history. Prior to the first world war men wore pocket watches and it would be considered feminine to wear a wrist watch. When I first started tinkering on watch movements I remember wrecking at least two good movements. Go for CHEAP first until you develop your own skills.
Regards
Tony
Sent from my SM-G900F using Tapatalk
Beware the cylinder escapement! I struggled with one of these a while back and there are a few things worth noting.
Firstly, unlike a lever escapement, if there is any power left in the mainspring, it will be released by removing the balance. Make sure you let the power down first or you may end up losing a pivot as the wheels all spin round like mad.
Second, you appear to have plenty of extra hairspring to re-pin it with the regulator centered if necessary. This appears to be normal practice for a cylinder escapement. On most lever escapements you will find the hairsprng cut close to the stud.
Thirdly, cylinders and their escape wheels wear out. Check the unlocking on each tooth.
Hopefully I won't upset anyone by posting a link to a forum I used before I found this one but see advice I was given here http://mb.nawcc.org/showthread.php?119907-Medana-(MST-274)-Cylinder-Movement-Running-Slow
If you can track down the two books referenced, then there is some good info there on cylinders.
Good luck!
S
I really appreciate your good advice, thanks!
And Stuart, that is very helpful information.
I think I will practice on a FHF 97, another Unitas 6325 and two movements I found on ebay, an old Timex (don't know the exact caliber yet...) and a relatively cheap Chinese 2824-2-clone. Hopefully I will improve on my technique and learn more about the movement layouts and mechanics. I will probable case the 2824-2-replica. I also have to learn about changing watch glasses and about a thousand other things... Something for the looong winter nights.
After that I will consider a Timegrapher of a reasonable price :startle:
Pauli
Nothing is definite in vintage watches. Crude soldering could point to a pocket watch conversion but there could be other reasons such as the lugs being repaired at some time. Wish you well in your endeavours. The secret is to take your time. Don't set time limits. Spend as much time studying the movement as working on it.
Best Regards
Tony
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.
