Can Anyone Identify These Tools?
Hamish
Hi, a while ago when searching on line I saw something I wanted in one of these 'watchmakers lots'. I bought the lot and after it arrived I noticed these othertools in there.
The first tool is brass and is 50mm in diameter. The grey areas you see are rubber. The holes are all the same and 9mm across. I hope the pictures say the rest.
The second set of tools appear to come in a set of sizes. At first I thought they were something to do with mainsprings, but now am not sure. There is a name 'Eterna' on the side of all of them with numbers from 1 (the smallest) on up. There is another number on some. These numbers are 1159 and 1319 which are Eterna calibers (I think), The interesting thing is that they appear to work consistent with mainspring winders, except there is no little tang for the spring to hook into. Where this would be is a cutting edge of some kind which leads me to think they could be a reamer of sorts.
I contacted Eterna and they have no idea. The lengths are approximately 100mm.
I am a bit of a fan of old vintage tools and I think its interesting how many 'spin off' hobbies can happen from general watch repair.
Hoping you can help.
Hamish.
post-1190-0-07042600-1449360356_thumb.jppost-1190-0-44349100-1449360401_thumb.jppost-1190-0-17348900-1449360454_thumb.jppost-1190-0-20629900-1449360500_thumb.jppost-1190-0-43981200-1449360557_thumb.jppost-1190-0-12380600-1449360584_thumb.jppost-1190-0-34341100-1449360640_thumb.jp
The name eterna is a watch movement make. Clockboy could be right saying its M/spring winders could be for eterna watches but I don't see why you couldn't use them for any movements providing you have the right size. The flat looking disks I haven't a clue.
The disk thing could possibly be used to allow you to reverse the direction of springs for fitting in barrels. IE wind the spring in a winder, insert into suitable hole in the disk with the brass blank in place. Now twist the brass cover out of the way and press the spring into the barrel from the disk by pressing on the rubber.
I think that the Eterna winders are possibly for installing the slipping bridle into the barrel in the good old days when the bridle was a separate piece and the actual main spring was just an ordinary manual type spring. The clue is in the size of the winders arbor, it's way too big for a main spring. Just a guess.
Thanks Guys,
Yes I thought something to do with mainspring winders as well, but cannot see how it would work (looking at last photo) as there is nothing to hook the mainspring onto to wind it and also the size of the 'barrel' nearly displaces all the space available in the receiver. (Not sure if this makes sense).
It looks like a cutting edge on the barrel and it is sharp....maybe something to do with cutting or smoothing the inside of a mainspring barrel side? Then I don't understand what the cut out area in the receiver would be for...
Oh well...I'll just consign them to the back of a drawer...thanks for all your suggestions.
Hamish
I've seen the first item for sale before (think I might even have one somewhere :D ) listed as balance screw & timing washer holder. I imagine the idea is when working on the balance to keep the washers with the screws they were on, and in the right order. Then it can be twisted closed to keep them safe - that's what I'm going for anyway.
Stephen
    • I suppose this fits "best" in this forum 😃 Im looking for some wall 'art' that doubles as a reference. Specifically Id like to find an ETA 28xx or Sellita exploded movement view. 2824/2836 would be ideal. Have any of you seen/found such a thing - there seem to be a lot of these for specialized movements, and none of them ready to print or to be had as a poster. Why help is appreciated.
    • The diameter is that of the ring - afaik, will have to look it up. “Wiggle room“ doesn‘t matter as long as the spring length is in the ball park.  Essential sizes of a mainspring are thickness, width and length. Diameter is just a hint if you can push into the barrel directly or will need a winder, it is no property of the spring. Frank
    • Hi @Zendoc, I guess you're like me and you don't have a mainspring winder.  I searched GR mainspring for the AS 1686 mainspring and I now understand your dilemma. The exact one is discontinued. To answer you question more directly, I see two good alternatives for you: a) GR4485 with 1.60 x .10 x 280 x 8.5 ( I guess this one is the one you found): https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/GR4485 OR b) GR4477 with 1.60 x .095 x 320 x 9. https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/gr4477   As you know, the the AS 1686 spring is supposed to be 1.60 x .10 x 300 x 9. - both of the above will fit and you'll manage to insert them from the retention ring without need for a mainspring winder (provided you know how to do it). - GR4485 will give you more power (=higher amplitude), but less power reserve (due to shorter length) than the original. - GR4477 will give you the same power reserve as the original. However, a bit less power.   Personally, I'd take GR4477 for two reasons: 1. Well, the power reserve is better. 2. With modern lubricants and modern mainspring metal alloys, you tend to get a higher amplitude anyways. You'd maybe even end up with too much amplitude (knocking) if you go with the original size and use thin synthetic oils-- see discussion here: https://www.watchrepairtalk.com/topic/10580-omega-calt17-help/#comment-248101
    • Your setup is correct. The smallest diameter of one pulley must correspond with the largest of the other one, else not speed variation. Frank
