What do you recommend? I generally put it in the elma machine with everything else, and so far had no problems. But I've read that some solutions can loosen shellac, and the heater stage may do the same. I'm currently servicing a 70 year old Landeron 48 and I don't want to have to source another one.
Ronsonol lighter fluid is what I always used it doesn't harm  shellac. You need a small pot with a screw lid as it evaporates very quick. You could leave parts in it for days and it will not harm them.
I concur with AndyGSI , clean by hand,
Repeatedly peg the face of pallets with a toothpick dipped in lighter fluid, wipe , repeat ...and finally rinse .
You might find repeating  ten times frustrating but TG smiles specially if it a well adjusted fork.
Repalcing , adjusting pallets or replacing with brand new fork complete  is like heart surgery, its part of the watch's heart.
Newness of fork complete doesn't mean the heart beat will be healthy.
Rgds
Edited by Nucejoe
correction
55 minutes ago, Bonefixer said:
I've got Renata Essence, which smells exactly like B-dip, so possibly the same. Is that suitable?
Yes, it’s basically formulated for balances so will work fine for pallets too
Tom
8 hours ago, AndyGSi said:
I've never put a pallet fork anywhere near a machine, always just dipped and cleaned by hand.
I assumed everyone stuck them in the cleaning machine with all the other bits. I always clean them in the ultrasonic with Elma fluids, and I've never had any problems.
Do you clean balance jewels by hand too ?
Balance jewels can go in ultrasonic.
Pegging cap stones, drop flat face of the stone on a piece of rough surface cardboard, push down on the stone with finger, pour some lighter fluid on it, scrub till you get a perfect shiny surface & rinse.
I know of no trick to clean inside of chaton, other than ultrasonic.
Much depends on how expensive of a piece your working on, spend as much time as neccessary to clean Grand Seiko fork.
Rgds
Edited by Nucejoe
spelling
Me, too. Mine go in a little basket then the big basket for cleaning machine. Never an issue. I do usually try to drop the balance in the hairspring cleaner and blow bubbles 😁
I clean the pallet fork with pegwood and rodico. After that it goes in a small jar with hexane in the ultrasonic. Never in the machine.
The balance jewels are cleaned with pegwood, then rubbed in IPA on a piece of paper. Chaton: pegwood-rodico-hexane.
Edited by caseback
That's what I do for pallets. But with shock protected balances, I clean in the ultrasonic with the balance fitted to the mainplate. The caps/chatons also get the ultrasonic treatment - they go in a contact lens case with cleaning fluid.  For non-shock balances, I put the balance+hairspring in it's own little basket, then normal ultrasonic clean.
In fact, the only things I don't put in the ultrasonic are the very tiniest screws, and small springs which can escape through mesh baskets.
Same.
1 hour ago, AndyGSi said:
For what's involved with cleaning a jewel I do that by hand too.
Same again, i never let the little blighters leave my sight 🙂
1 minute ago, Klassiker said:
@all of the people saying "never in the machine", is that because of fear of what you imagine might happen, or due to actual bad experience?
Fear of what MIGHT happen DUE to actual bad experience 😅. Not all ultrasonic cleaner are equal, i think mine has shellac rage 😅
I swear i could feel one of my front teeth slowly coming loose while i was stood over it yesterday 😅
  • Haha 3
This discussion has expanded beyond my initial query, which is fine.
For balance wheel, I've taken to mounting it on the main plate, removing the jewels (and closing the springs) then into the machine in its own compartment in the basket. Is that ok? The jewels I do in one dip.
That is the generally accepted way of doing it.
 Mostly fear,  as I haven't actually got my hands on some cleaning solutions you guys have, bad results though in ultrasonic with all solutions in my disposal. Wonder if  my cheap ultrasonic has to do with shellac loss.
Rgds
Do you know that an ultrasonic cleaner can generate more than 120dB of sound in a enclosed room?
I think most of us here are over fifty years old and the natural decline in hearing of high frequencies allows us to be in the same room as a working ultrasonic cleaner.
When I was still working as a dentist, whenever I had a young child in my surgery and the ultrasonic cleaner was turned on, they would cringe and clap their hands over their ears.
I tested the noise level in the room with the ultrasonic cleaner and was shocked. My cheap Radio Shack sound meter went off the scale, even as far as 6 feet away.
Even the tiny ultrasonic scaler that we used for cleaning teeth can generate more than 120dB at a distance of 1 inch away. I can't imagine the actual sound level the patient is subjected to when the tip of the scaler touches the tooth and the sound is conducted through flesh and bone to the eardrums.
No wonder patients never like going to the dentist. And why most dentist are hard of hearing. 🤣
But coming back to the topic, ultrasonic cleaners come in different powers. My mentor uses a 60W and he throws everything into it, including pallet forks and balance wheels and never had any problem.
I have a 120W model and have lost shellac after a 10mins of cleaning. So now I only clean the pallet fork by hand.
We know using different materials for the containers in a US can affect how powerful the cavitations are inside them.  Plastic , glass, and steel differ in how much energy can pass through. I used to use the aluminium cases that tea light candles fit into to float on the surface of the water tank... mostly for cleaning hairsprings, balances and levers of pin pallet movements....after half a dozen uses the bubbles start to punch through. Switched over to tin screw-on bottle tops which last a bit longer or a heavier gauge metal tin which numbs the energy a little morel..compare this to watch parts in steel mesh baskets in a plastic basket holder in a glass jar. Big differences with experiences of how we all clean, heat in the water tank is also known to reduce cavitation size.
Mine is 60W and I've had no problems with shellac. I chose that power as the pro cleaning machines are 50-60W.
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
