A Eureka Moment !
A couple of days ago someone brought in a 1930's Haller clock with Westminster chimes for repair,
the clock was working but would only strike once regardless of the hour, I also noticed a lot of mechanical noise when the Westminster train was running. The fault was traced to a rod out of adjustment & a bent lever, probably the result of rough handling by a previous tinkerer ! , the clock is now back together running nicely & telling everyone the time ! I wish they were all like that !   :D
Clever clock!
It's a great feeling when you get to the bottom of the problem and fix it........well done.
When I worked on cars for living years ago, we had a sign in the office....
Labour Rate:
$75/hr
$100/hr if you watch us work on it...
$125/hr if you worked on it before you brought it to me!
Labour Rate:
$75/hr
Isn't it amazing what people do to save money !    :startle:    :money:
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
