Stereo Microscope
Hi all, this thread has been a great source of info on microscopes and excellent for a complete newbie as myself.
Ive decided to go with a microscope straight away as one consistent comment I’ve seen online is people stating that they wish they had purchased one earlier.
The issue I have is which one.  I found what looks like a decent Eakins item for about $360.
https://www.aliexpress.com/item/33007792373.html?spm=a2g0o.cart.0.0.5ce238daQnygLt&mp=1
However there’s others that look exactly the same with the same in the package details such s the one below for a couple of hundred more.
https://www.aliexpress.com/item/1005003181895694.html?spm=a2g0o.cart.0.0.1b9638damFQUhn&mp=1
Given that both list cameras only as options I’m inclined to go with the cheaper item given that they seem to have the same specs.  Are these really the same or am I missing something.
Pairing with a camera seems to be the difference and the black microscopes are a bit more expensive than the white ones.  I would recommend getting it without a camera.  Take your time and find a camera that you will be happy with.  The ones that come with the microscopes are hard to find much information on.
That’s what I thought at first but a YouTuber did a review where the front page showed a camera but when it didn’t come he checked and the package list on the website listed the camera as an option.  Both of the microscopes I linked had the same.
it seems a tad shady the way they are listed but the $360 item seems ok. I concur with the camera I’ll get the scope then work out the camera later. After a bit more research.
Thanks for the advice.
I think it is a problem with the website.  The first option should be without camera, but the photo you see has a camera.  If you select another option and then go back to the first, you will see the no camera photo.
1 hour ago, Razz said:
Check the shipping, looks to be over $200.
It seems they do that to keep your import duties lower, instead of bundling that in the price.
12 hours ago, Razz said:
Looks okay and has all the assesories. Check the shipping, looks to be over $200.
Yes the shipping is ridiculous but it appears that they all have similar rates to Australia.  I'm guessing the weight and dimensions exceed some sort of limit for low cost freight to Au.
3 hours ago, spectre6000 said:
These things are HEAVY. On the order of 65 pounds if memory serves. Comes in two large, well padded boxes.
Mine came in one quite heavy box.  I don't doubt that shipping is expensive on these microscopes.
The Eakins has finally arrived in one very heavy box, now I need to sort out a suitable camera and dedicated desk as I currently on,y have my computer desk.  I’m thinking those electric sit stand desks might work as I can adjust the height as needed.
Hello all,
So for my birthday, I asked my wife for a stereo-microscope (actually, I told her exactly which one I wanted).
I've read many times (and seen this video of Alex https://youtu.be/tAtATqwI5A4?si=NlU3TwHFBwpDKitw) that a good stereo microscope would be a "game changer".
I resisted for the longest time, and ended up buying a staking set, jewelling set, glass press... heck, even a Jacot tool.
But now I made the jump.
And OH MY GOODNESS, it is so much more amazing and "game changing" than I ever imagined.
I go the Amscope SM-3TP (https://amscope.com/products/c-sm-3tp-hd), with light ring and 0.5 Barlow lens.
It delivers the perfect amount of magnification and working distance.
(Please note that the 3TP version allows you to use full stereo vision while using the camera port at the same time. The 3T version used by Alex (see video link about) will force you to either use stereo-vision for your eyes and NOT use the camera port at all, OR use the camera port but only have mono-vision on your eyes. The camera port and the left eyepiece share the same "tunnel" and there's a lever that you pull/push to decide which one is active. I definitely recommend paying 20 bucks more to get the 3TP.)
I think that one really needs to experience a stereo microscope like this to fully appreciate how incredible it is. Pictures (which are two-dimensional) will never do it justice.
To see three-dimensionally is SOOOOO useful. I've never oiled a pallet stone with such perfect accuracy and ease. And I can see in perfect clarity how the drop of oil spreads over the next 3-5 escape wheel teeth. Until I apply another perfect drop in the perfect spot.
And INSPECTION: my goodness. You'll find the tiniest speck of dust or debris with ease.
Honestly, I'm over the moon with this new acquisition. After using it for 3 days, I can't even imaging how I lived without it.
  • Like 7
IMHO, no truly serious work can be done before you get a stereo microscope for the simple reason that you can't really see what you're doing and the result of it. Congrats! 👍
I have a height adjustable desk and it's fantastic. Gives you so much flexibility to switch between microscope and non-microscope work. Also when working with the microscope only, you'll change the working height (your eye-level) frequently. Your back/neck will thank you very much for an adjustable desk!
A microscope takes the horological experience to a different level. Parts that you thought were clean are not, parts that you see no fault are faulty. I am greedy I have one over my lathe + two on my desktop one powerful Olympus which gives in incredible clarity and a AmScope which gives a high working space..
Also a digital scope purchased for me by my other half, its clarity is poor but does give the ability to copy what’s in view.
Edited by clockboy
Haha, I second that one!!! It's incredible.
Now brace yourself for when you realize it has uses beyond watchmaking! Recently in another sphere of lunacy, I've been digging into leathers from different species to try to figure out how to tell the difference (specifically between horse and cow leathers). Also very useful for making/repairing electronics. Also, I modified a watch oiler (the biggest one in the set that never seemed to get any use) to fix skips in vinyl records. Also, I found micrometeorites in the driveway with my daughter (lots more coming on that front no doubt). Like you, I was very much on the fence about buying a microscope, and I have ended up using it for so many things beyond what I thought I would.
I've been using my scope for non-watchmaking things lately, so this may be of limited application... I found that the lack of magnification on the camera compared to what I'm seeing in the eyepieces was problematic. Combined with the reduced field of vision, it's a bit of a conundrum. I ended up getting a phone mount with 3 axes of adjustability, and have been taking photos that way when I want to see more than the camera can see. I haven't had a chance to look into the existence of magnification for the camera port to match the eyepieces, but then you'd certainly run into the field of vision limitation again... That seems to be more a limitation of the camera/scope as a whole than any particular model, but throwing that out there as something I've run into lately.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
