Blew it with a coil
I'm sure you will get help on here soon.
Kkramme we like new members to make an introduction before posting. A little about your self such as where you life and what got you interested in Horology
Thanks. I did make a self introduction— perhaps in the wrong place? 🤔😢In any I am an Australian 🇦🇺 American living in the beautiful Gold Coast, Queensland Australia. I love Grand Seiko and Seiko watches, and recently came back from the Grand Seiko Shizukuishi Studio in northern Japan where I was blown away by the design artistry and technical excellence. More later on that (including photos, if interested!)
Here are some photos of the undamaged and damaged coil.  My bad!  I find it interesting because it is an "old" Seiko Credor -- which later evolved into $20K watches!
Sometimes surface damage like this can be repaired with solder. Run pre-tinned soldering iron tip with a tiny blob of solder over the damaged area and pray that the Gods of watchmaking are on your side. 🤞
the problem with vintage watches and yes quartz watches can be vintage is availability of parts will be a problem. I have a link below where we can cross reference the coil and  I was hoping for more.
Another problem for vintage parts are everyone on the group gets used to ordering from online. Conceivably the physical material houses that still exist out there might have the part and you'd have to reach out to them and see if anyone has one. this is because they don't list every single part that they have online with the exception of cousins where everything they do is online work just doesn't exist but the other material houses can have stuff not listed.
Otherwise just set up a search on eBay and sooner or later it will possibly show up if you're lucky.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_6020A
17 hours ago, HectorLooi said:
You don't have to use his special tester. Any good multimeter would work.
Thanks.🙏 Very helpful.
13 hours ago, watchweasol said:
Hi. Breaks like this can br fixed with conductive paint like the paint used to repair a car  rear screen heater. I have used it successfully, you don’t need much and unlike solder there is no heat
What a cool and talented and helpful group/community!   Well done -- and much appreciated!
14 minutes ago, CYCLOPS said:
Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.
I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
Hi. It’s always better to replace the coil but in the event of being unable to find one it’s nice to know that repairs can be effected. I prefer the conductive paint option because of the lack of heat and the chance of causing further damage.
Would the paint increase the resistance of the coil ?
Effectively joining the wires that are painted. I imagine its important to only paint the smallest of areas to make the repair.
41 minutes ago, watchweasol said:
In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
Thanks ww, its maybe not as much of a bodge trick that i thought it was.
On 4/27/2024 at 4:11 AM, watchweasol said:
Hi New. More of a get you out of a hole than a bodge. There is no substitute for a new coil.
Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
