Introduction
Hello all.
Now approaching my mid 30's I've had a sudden love for knitted jumpers and trying to spend my time off work doing something positive. I have decided on giving watch tinkering ago. I am afraid I am a fan of Armani watches and I now own 2 that are not ticking and another that works but has a broken crystal. I have gone through the past threads and there is some great information regarding Armani's and how to get started. They seem to be a pedantic time piece, but I'm hoping any snags that might happen have hopefully already been explained and solved in past conversations . But if I get swamped I'd be very appreciative of any advice anyone could spare me. Many thanks!
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Did you order Chinese tools, because if you did you are not the only one that is sent total crap.
I am afraid so. They sent out another set and let me keep the fork, which was very kind of them. But unsurprisingly the pry tools are far too thick to be used on watches without damaging them. I would be better of using the fork tbh. Oh well lesson learnt.
They got me again lads! Temu's finest. Fool me once shame on you, fool me twice and I'll just complain about it on a forum. I'm thinking good tools ain't cheap and cheap tools ain't good hah!
1 hour ago, oldhippy said:
Send the bloody things back. These are not expensive but they will get you started.
 https://www.hswalsh.com/jewellery-tools-equipment/jewellers-bench-tools/jewellers-watchmakers-pliers/economy
Cheers Hipps! I've ordered myself a couple of long and short nosed plyers. I'll leave Temu for the Mrs birthday presents 😉
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
