Andyclient
Use a screwdriver instead of a pointy tweezer to depress the setting lever as this will prevent you pushing it too far. Pushing too far can cause the yoke to slip over the clutch wheel and then you need to do some dismantling to resolve that.
I changed a canon pinion and a winding pinion on a 2804, and I only removed the barrel bridge. After removing the stem and the pinion I had trouble putting them back. So the next time I did that I pulled the stem out from position 2. This way, when putting all back, the winding pinion just stayed on the yoke instead of me having to push the yoke back for the winding pinion to find it's place (I hope you know what I mean).
p.s. @Mark, any more videos on the way? It's been more than a month since the last one. Personally I check your youtube channel at least twice a day.
    • Could it be an abbreviation for Denier? "Denier (/ˈdɛniər/) or den (abbreviated D), a unit of measure for the linear mass density of fibers, is the mass in grams per 9,000 metres of the fiber. The denier is based on a natural reference: a single strand of silk is approximately one denier; a 9,000-metre strand of silk weighs about one gram." The pivot gauge looks interesting, however I wouldn't trust myself to drive a pivot into a wedge incase it jams and gets damaged/snaps trying to get it free. More a comment on my ability and incompetence than the quality or design of the tool 🤣
    • @clockboy The damage on the movement much worse. The images against the green background are my watch the other 2 are from the internet. The rotor has erased the perlage. I am surprised how is this watch still running.
    • Hi All, I recently bought a few gauges on Ebay. One of those was my actual target, a roller jewel gauge. Pictured below was one of the other gauges I received. From what I gather, this one is for measuring pivots. No sure if I'm right here. A confirmation of my assumption would be great. The gauge also has an abbreviation of "DEN". I have looked around and don't find this relative to watchmaking. Any clue to what this abbreviation means? Thanks, Don
    • Hello and welcome to the forum. Te attached file my help you repair a few. TZIllustratedGlossary.pdf
