Hello all.  Been falling down this watch repair rabbit hole for several months now.  All started after I bought myself a Rollie as an investment, and watched a service video.  Then got hooked on all these videos - Wristwatch Revival, French Watch Collector, Nekkid Watchmaker... - and fancied having a go myself. And I've been collecting more watches too.
I bought a Rotate watches kit, and managed to disassemble the included movements, and reassemble 2 out of 3 successfully (I broke the escape wheel pivots on one of them).  Since then I've been accumulating tools, buying old watches off ebay and doing my best to fix them up, with some success.
Am thinking of doing servicing as a part-time hobby/career once I retire from my day-job in a few years, and in the meantime will get more tools, more experience, complete the courses, and get my confidence up with servicing some of my own watches before taking on customers.
Bonefixer
Welcome. Way to go!
Make sure you watch Chronoglide. Deals nearly always with what problems occur and what may have caused it. It gives the ability to understand and apply Mark's level 3.
Edited by rossjackson01
Spelling, Grammar
7 hours ago, rossjackson01 said:
Bonefixer
Welcome. Way to go!
I’ve watched some. I like the guy but he talks too much. I sit there thinking “just get to the point”🙄
7 hours ago, rehajm said:
Do you know Roger Smith? 😄
I know of him, and his mentor the late George Daniels. I could just knock on his door and ask for help removing my broken arbor screw I suppose 🤣
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
