Hello from Central Florida (@timeshed)
My name is Eric, and I have been getting such good info from this forum, so I decided to go ahead and register.
I've been a software engineer for 20+ years, collecting vintage watches and getting into repair more recently.
I'm a huge fan of Tudor and Seiko, having gotten into watches mostly through my first purchases of these two brands, mainly on the vintage side of Seiko watches. Just wanted to intorduce myself and hopefully I can share my journey and add some value somewhere. Hope to meet a lot of those who have helped me on my journey and help others too.
I've noticed others posting in here some of their experience so here is mine:
I started developing my skills by taking apart cheap HMT movements from several HMT watches I scored on Ebay. I guess I shouldn't have started with such small watches, but I've successfully taken a few apart and got one back together and working.
Learning from that experience, I purchased a G.S.T.P. Pocket Watch (WWII) to practice on a larger movement.
That's where I'm at now, and hopefully, I will get this one working, but then I learned my second lesson, and that is, maybe not start with a movement that it will be hard to get donor parts for.
I have all the basic tools, good screwdrivers, several Moebius oils and greases, a timegrapher, a movement holder, and lots of stuff, but I have learned the most important thing to have is magnification in different levels and PATIENCE.
  • 4 weeks later...
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
