Introduction
RSP
Hi I'm Roger,
I'm a retired mechanical engineer and have an amature interest in watch repair which I have carried out for family and friends.
I have joined to improve my knowledge of watches and watch repair and hopefully when needed  acquire help and advise from other members.
Hello  @ken56Hello and welcome to the forum.  (Rabbit hole)   Enjoy.
regarding the omega   Ticking no hand movement, one would think it’s in the region of the canon pinion / hour wheel area, not forgetting the center wheel.  The omega is not the best of training watches as they are finely built and easily damaged. If this is your first adventure I would advise getting a cheap working watch to practise on before having a go at the omega so as to gather the skills. I assume you already have sufficient tools for the job in your possession.
By the way what caliber is the omega and can you pot some oic5ures of the movement please
    • I used to have a lecturer during my Engineering classes who was always beating a drum about quoting units, I remember one day he was so exasperated with our class he said "quote your units!!!!...I don't care what units JUST QUOTE THEM!!!" My next assignment I calculated the velocity and quoted the units, something along the lines of: "Thus the velocity of the body will be 0.00345 furlongs per fortnight" He graded my work as an F, then crossed it out and gave me an A+, turns out he had a sense of humor after all.
    • Just to add to what @Neverenoughwatches says, the impulse jewel on the balance wheel is also held in by shellac, so avoid exposing the assembly to IPA as well - as stated the one-dip and generic tetrachloroethylene equivalent is safe with shellac so you can use this for your pallet fork and balance assembly. I agree, but worth noting that IPA readily soaks up water, even from the atmosphere: "IPA exposed to the air will absorb moisture rapidly until it reaches an equilibrium value of 65% IPA to 35% water." So you need to refresh it regularly.
    • The width is otherwise known as mainspring height and strength as thickness for us more modern guys.
    • I've remembered something I had forgotten.  I've come across Dennison before but forgot all about it as I'm never going to use the units.  Maybe we should start a  thread on obscure units of measurement.
    • Learned a new thing today! 🤓 Looked this up and found this informative document: Watkins-MainspringGauges.pdf
