Cartier repair
hel
Hello lovely people
I have this watch, I can't find any info and I am yet to take the back off.
I know zilch about watches but got this at a second hand store.
It is beaten up.
What are the chances of it being real or will you tell me I am dreaming 😆
Would appreciate any info you are willing and able to give.
Thankyou
Helen
12 hours ago, hel said:
Hello lovely people
It is beaten up.
Thankyou
Helen
Its just wrong, all wrong. Even if it were right it would still be wrong. Time to wake up sorry, this would have probably been in a vermeil case if it were genuine.  The Cartier brand is well known to be have been extensively faked over the years . A peek inside may well reveal its Far Eastern origin .
Haha thankyou so much. I will attempt to look inside and maybe get a pic.
6 hours ago, RichardHarris123 said:
I think fake. Even if not, it looks badly corroded and with the crown and stem missing, probably corroded inside.  Take the back off, let's have a look.
So the back is proving very difficult to remove. Any tips?
Ok, I'm almost too embarrassed to post this pic 🤣
So after much struggling I got the back off to reveal this 😂😂
It says
Unadjusted
Myota Co
Japan
Thanks so much for the replies.
The band might clean up well 😆
Much appreciated
It says
Unadjusted
Myota Co
Japan
Much appreciated
Holy crud Batman, I'd say that battery is toast, i mean it actually looks like a piece of  burnt toast 🔥 or a muffin even, i would have to butter it first before i put it in the bin . I've seen worse inside a watch, i cant remember when or where I've seen worse but i probably have or maybe not. OH's suggestion to bin it is too good for it, i think i must make a watch crush for watches like this.  Keep looking Helen, one day it will happen, I'll try not to be so harsh next time, i applaud  your bravery to show us though, many dont even reply.
If it is a fake they faked a Must and not a Cartier😂?
You may have been innit just for the treasure hunting but If you like the idea of improving this tis true you could replace the movement without much expense and cleanup the case and band. The dial is in good shape…
I have no suggestions on the..bezel thing? What is that? Could that have been plated or painted at one time? Ugh…sorry, now I vote bin…
Haha when you know you know and yes mate tis true you know 🤣 . Poor Helen all this jibe, we are sorry H we are quite naughty today please forgive us.
  • Haha 2
Far be it for me to discourage a little treasure hunting. Last year paid a couple hundred gbp for an auction lot for ‘costume jewelry’ and a couple watches, one clearly a Bell & Ross or Bell & Ross fake. The wife wanted the baubles so I paid more than I should…though those pearls in there do look real, don’t they? Well the pearls are real- 3k worth and I have a lovely Bell & Ross fake with a Chinese movement that puts the timekeeping on my iPhone to shame 🤪. Happy hunting…
3 minutes ago, watchweasol said:
Hi. A good dose of elbow grease and a new movement  approx £10. To £12  and you have a decent time piece  might not be the real thing but brought back to life, worth a bash in my opinion. Go for it.
Just the sense of achievement and lessons learnt can be more than worth it. I'm battling at the moment with an old cylinder esc. movement that is worthless. Trying to make a new plug for the cylinder or slowly but surely file in a new pivot on the old one. In the process I've learnt that turning a balance staff is a real skill but not beyond my ability. All lessons learn are worth the effort.
Thanks everyone for your input!
Quite the funny banter here 🤣
I did consider a new movement and clean up attempt but it had an inlay around the face that was broken so alas it has gone to watch heaven.
Appreciate all the responses from the actual watch worthy 👌 😁
That big find is just around the corner H , just keep believing.
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
